Odd engine trouble
Posted: Fri Mar 07, 2014 10:27 am
by Shoppinit
Hello peeps.
Would appreciate a bit of help troubleshooting this off problem with odd symptoms but no obvious connection. Well, I can think of one, but I don't want to taint others' views.
So the symptoms are this:
1. No more one-touch start - you have to hold the start button in to keep it turning over
2. Revs don't come back down quickly after blipping throttle - results in jerky gear changes
3. Cruise control not engageable.
Anyone seen these symptoms together before?
CheeRS!
/edit: forgot to mention, I'm not with the car at the moment but will scan it ASAFP.
Re: Odd engine trouble
Posted: Fri Mar 07, 2014 10:32 am
by alex020869
Sounds like your clutch switch is faulty.
Cheap fix and only 10 mins work.
Alex
Posted: Fri Mar 07, 2014 11:03 am
by rs4Mav
Defiantly your clutch peddle switch, I had the same symptoms end of last year on mine.
New switch from Audi stealers £17, fitted myself in just under 15 minutes, job done.
Just make sure you don't push the plunger in on the new switch before fitting, as this will make it useless, if you do a search on here you will find full guide on how to install it.
Posted: Fri Mar 07, 2014 11:16 am
by Shoppinit
Ace. Thanks. I was thinking accelerator pedal issue, but clutch switch makes sense. Will a DTC be logged? I do like positive confirmation.
Posted: Fri Mar 07, 2014 1:50 pm
by pandavet
Hi guys, thank you for your help. :beerchug:
The log shows effectively a clutch pedal switch default : 20€, 5 minutes... Well, 20€ for me, and 5' for Shoppinit... :biggrin3:
I can relax now.
JP
Posted: Fri Mar 07, 2014 6:13 pm
by PetrolDave
alex020869 wrote:Sounds like your clutch switch is faulty.
+1
Those are the 3 classic symptoms of the clutch switch having failed.
Posted: Fri Mar 07, 2014 7:42 pm
by coffey555
I did my one last week. Make sure you turn the new switch firmly fully clockwise when fitting (you will hear and feel an audible click when it is fully home) otherwise nothing will happen when you press the start button.
Posted: Fri Mar 07, 2014 8:54 pm
by C17LJR
I've just got the same symptoms, better get one ordered
Posted: Sat Mar 08, 2014 7:53 am
by pandavet
@coffey555 : yep, the Audi tech told me the same. ;)
JP
