Page 1 of 3
finally got the 20s on....
Posted: Sun Feb 23, 2014 2:57 pm
by m3dne
managed to get the new wheels fitted yesterday, 9x20 with 255 30 gy eagle f1s, .... after all the messing and spacer issues with the 10x20s just ended up going for the rotors, not touched the suspension yet but drives surprisinly well on standard set up. :beerchug:
afew pics..
Re: finally got the 20s on....
Posted: Sun Feb 23, 2014 3:00 pm
by C17LJR
Looking good. What you thinking suspension wise?
Posted: Sun Feb 23, 2014 3:28 pm
by CellDamage
What's that badge under your RS4 one?
Posted: Sun Feb 23, 2014 3:35 pm
by m3dne
C17LJR wrote:Looking good. What you thinking suspension wise?
not sure yet, my brother has coilovers on his rs4 and it has a very harsh ride, was thinking h&r springs keeping the drc system???
Posted: Sun Feb 23, 2014 3:36 pm
by m3dne
CellDamage wrote:What's that badge under your RS4 one?
its a quattro badge under the rs4..
Posted: Sun Feb 23, 2014 3:37 pm
by Rick_RS4
quattro.
look good mate, im biased tho, rotors are popular now, but look ace imo
Posted: Sun Feb 23, 2014 4:42 pm
by jaysrs4
I've got H&R's on mine only problem is the fronts, the car sits too level.
The rear is perfect, with the tyre walls sitting about a quarter under the arches but there is still a gap up front.
It's far from reverse rake but I'm going to get the front springs modified by a company that make race suspension and springs in Sheffield, they just need about 10mm for it to sit perfect.
So if your a bit anal about your stance I don't think you'll be 100% with springs alone without modifying them.
Posted: Sun Feb 23, 2014 4:51 pm
by sar
jaysrs4 wrote:I've got H&R's on mine only problem is the fronts, the car sits too level.
maybe try the b5 spring perch mod drops the front by about 3/4 inch?, less hassle than getting the springs modified.
Posted: Sun Feb 23, 2014 5:06 pm
by John Johnson
Coil springs 1989 ? Used them a lot a few others have
Posted: Sun Feb 23, 2014 5:07 pm
by sar
soz meant 3/8 inch
by jaysrs4
Ah please tell me more!!
Posted: Sun Feb 23, 2014 5:33 pm
by jaysrs4
Thanks Sar for the heads up on this. Been doing some Audizine searching and looks like I'll be off down to Audi in the week!
Lower B5 front spring perches/plates - I assume the fools in parts will know what I'm talking about?!
Posted: Sun Feb 23, 2014 11:19 pm
by MikeFish
Or you could go for the kw adjustable spring kit. This means you keep the DRC but can still set the ride height as you like it.
Obviously, i'm a fan of rotors too.
Posted: Thu Jan 08, 2015 6:21 pm
by m3dne
Just a update on my rs4... changed the headlights to clear.. fitted full leds inside and out off trupps.. much better( slight issue with the sidelight leds tho ) fitted led rear lights, Resonated valved Miltek catback, Revolution induction fitted, Rotors took off for winter. Rear tints done... a think thats it
Posted: Thu Jan 08, 2015 6:52 pm
by m3dne
Intake pic
