TPMS Fault - Antenna for Tire Pressure Monitoring Rear
Posted: Tue Dec 24, 2013 7:21 pm
Happy Holidays,
My TPMS is showing a fault, both the warning light and the "TPMS" fault in the HUD. I just activated TPMS using VAG-COM and installed wheel sensors as I didn't have them before. The sensors are not OEM. I have run the "Wheel Change" and "tyre pressure" procedures. I still had the warning lights.
Then I ran VAG-COM, I will display the result of after I installed and setup wheel sensors, and the before I installed wheel sensor so you can see the difference. It looks like some are working, but there is an issue with the rear sensors. Here are the results:
After:
Address 65: Tire Pressure Labels: 8E0-907-273.lbl
Part No SW: 8E0 907 273 A HW: 8E0 907 273 A
Component: Reifendruck 3 H04 0130
Coding: 0062523
Shop #: WSC 130816 028 588230
VCID: 2A5117D0861D074EEA7-5122
2 Faults Found:
01521 - Sensor for Tire Pressure
002 - Lower Limit Exceeded - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 3
Fault Frequency: 2
Reset counter: 40
Time Indication: 0
Freeze Frame:
(no units): 27.0
Voltage: 13.60 V
(no units): 19.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
01833 - Antenna for Tire Pressure Monitoring; Rear (R96)
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Freeze Frame:
(no units): 0.0
Voltage: 11.60 V
(no units): 130.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Before:
Coding: 0062523
Shop #: WSC 02197 785 00200
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Freeze Frame:
(no units): 111.0
Voltage: 13.60 V
(no units): 61.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 40
Time Indication: 0
Freeze Frame:
(no units): 90.0
Voltage: 13.70 V
(no units): 130.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
I'm going to adjust the pressures on the tires to 41 Front and 38 Rear from 36 Front and 33 Rear when I ran the test. I will see if that solves the first error - lower limit exceeded.
Any advice would be appreciated. Thanks in advance.
After:
Coding: 0062523
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 40
Time Indication: 0
Freeze Frame:
(no units): 27.0
Voltage: 13.60 V
(no units): 19.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Freeze Frame:
(no units): 0.0
Voltage: 11.60 V
(no units): 130.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Before:
Coding: 0062523
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Freeze Frame:
(no units): 111.0
Voltage: 13.60 V
(no units): 61.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 40
Time Indication: 0
Freeze Frame:
(no units): 90.0
Voltage: 13.70 V
(no units): 130.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
