Page 1 of 2
NEW FROM FORGE - B7 OIL COOLER KITS
Posted: Fri Dec 13, 2013 6:18 pm
by Revolution
Hi All
Now available from our website the new Forge Oil Cooler kit for the B7 RS4, no more leaky/corroding oil lines..........
http://www.revolution247.com/catalogue/ ... 4-42-v8-b7
Free delivery or half price fitting for the first 5 ordered......
Go on you know you want it.............
CheeRS
Little Glen
Re: NEW FROM FORGE - B7 OIL COOLER KITS
Posted: Fri Dec 13, 2013 7:09 pm
by Audi Pardner
What's the cost of the half price fitting then Glen? (Inc VAT)
Posted: Sat Dec 14, 2013 11:30 am
by Revolution
Audi Pardner wrote:What's the cost of the half price fitting then Glen? (Inc VAT)
Hi all
We will fit the first 5 for a paltry £100.00 of your ill gotten pounds
CheeRS
Little Glen
Posted: Sun Dec 15, 2013 12:53 am
by CellDamage
That's a good price for fitting, just had mine done elsewhere!
Posted: Sat Jan 11, 2014 10:15 pm
by Covkiller
I wish this kit was available this time last year, as I had to fit the OEM at great expense, oh well.
I saw this product at the Performance Car show today on the Forge stand, absolutely top quality.
Posted: Mon Jan 13, 2014 12:58 pm
by Revolution
Hi
Covkiller wrote:I wish this kit was available this time last year, as I had to fit the OEM at great expense, oh well.
Thats fine, you can get the Forge one from us when the OEM item goes again
CheeRS
Little Glen
Posted: Tue Jan 14, 2014 1:48 am
by Bladerider
I like the kit,
I just don't like the fact its been reverse priced from the Audi parts brochure so blatantly for a cooler that actually costs about £150 !!
If this kit had of been around the £500 mark as we were all kind of expecting then I think it would have been a thing of greatness and you would have sold bucketloads.
This isn't your fault, but I think Forge are taking the pish and i will never buy another one of their products again.
J.
Posted: Tue Jan 14, 2014 7:45 am
by Audi Pardner
Bladerider wrote:I like the kit,
J.
The problem is that there's little choice out there if you want to avoid the Audi OEM kit, which is generally acknowledged to be poor and likely to require replacing every 5 years or so. You could make up a kit by sourcing the component parts, Setrab cooler, braided pipes etc but you've got to work out how to connect them to the engine block. So the Forge kit or JHM replacement pipes are the only real fit-and-forget options IMO. I've gone with JHM as I'm not too keen on the position of the Forge cooler above the front impact bar in terms of air flow to the main rads, and the need to relocate the sensor below the bar. Both these options are expensive, but to my mind much better than the OEM option.
Posted: Tue Jan 14, 2014 3:00 pm
by jobbys
So car in with dealer having both Aux Rads replaced following a coolant leak.
Inevitably have been advised of corrosion on oil cooler couplings and quoted about £1400 to do it all (cooler & hoses with labour). So am considering my options. The forge kit is of interest but have a couple of questions:
* Talking with someone more mechanically minded (I know jack), issues were raised that the higher sitting cooler position of the Forge cooler means the oil can/will drain from it when engine is off. Is that a potential problem ? I note Forge make a point of the higher position to reduce risk of road debris damage, but that isn't much of a consideration for me.
* Does the change of the oil cooler achieve much ? The main issue with the Audi bits being the mixed metal (aluminium/steel) corrosion at the joints, rather than the performance of the oil cooler itself. With that in mind, does just using alternative hoses with matched metal connectors to an OEM oil cooler solve the problem? I'd prefer to stick as stock as possible when it comes to replacements.
I recognise the fact that I'm likely to have to replace the oil cooler being the difficulty in taking apart the corroded coupling. Though an independent more likely to give it a go with careful cutting of hoses whilst protecting threads, which is not in Audi dealer's interest to bother with.
Any comments?
Posted: Tue Jan 14, 2014 4:14 pm
by toyneg
jobbys wrote:So car in with dealer having both Aux Rads replaced following a coolant leak.
Any comments?
i look forward to responses on this as i am in the same boat with my car leaking oil and was wondering whether to go forge or OEM
Posted: Tue Jan 14, 2014 5:37 pm
by rocket1
i,m exactly the same position. after removing my bumper at weekend i noticed some oil drips at one end. hopefully this weekend i,ll strip the rest out and bring the cooler home to see whats what. if the pipes come off the cooler ok then its a no brainer just new oem hoses but if its a full replacement it will be decision time!
Posted: Tue Jan 14, 2014 6:28 pm
by Audi Pardner
Jobbys, toyneg & rocket1
If you haven't already, have look at some of the posts on the 'Yet another oil cooler question (well a few actually)' thread here. I'm in the middle of changing over to JHM pipes and new Audi cooler and am planning to do a mini thread for those who, like me, have problems with the standard set up. Or PM me if you want
Posted: Tue Jan 14, 2014 9:24 pm
by sar
i cant see the position of the forge oil cooler regarding oil draining being a problem.
i would be more concerned with it blocking flow over the main rad, probs not a problem for those of us in the uk with our temps but if you have the cold air feed and have already deleted one of your aux rads then on a hot day and if your giving it some this could start to add up. i would rather they used a similar size and shape to the oem cooler and kept it in its original position.
as for forge placing the oil cooler further up to minimize road debris damage i dont think they had a choice it simply would not have fitted in the oem location.
the "upgraded cooler" will offer no cooling benefits over oem, supercharged cars making 600+ bhp run the oem cooler with zero oil temp problems.
the problem like you say is the oem hoses with steel fittings, unfortunately its not going to be easy to make up your own set of pipes because of the non standard fitting audi use where the oil pipes connect to the block. the only people that are making an upgraded set of pipes with the correct fittings are jhm.
Any comments?
plenty on here have struggled removing the old pipes, when i do mine i think i will cut the pipe and thread straight off and weld new threads on to the cooler body. someone on here has already done this as the threads were to badly corroded/damaged by the time the steel fittings had been cut off.
and i think its worth mentioning that everyone who has had the forge kit fitted seems to be suffering from some weird rpm related harmonics vibration issue, which is causing an audible whine when reving the engine.
Posted: Tue Jan 14, 2014 9:44 pm
by TAB1S
Would any of you guys be interested in my spare cooler & pipes? Open to offers,
Its done 80k as far as im aware,cant see any history of it being replaced?
will put in parts for sale soon or on she bay if no intrest.
There was no sign of any leaks before it was removed.
Posted: Tue Jan 14, 2014 11:12 pm
by rocket1
pm,d you rick!
