Annoying Brake pad warning light! Arrgh!!
Posted: Mon Sep 16, 2013 11:35 am
Hi guys,
When I bought my car it needed new brake pads. I bought some Ferodo Premier Pads (with the sensors) and fitted them. Issue I have is the brake pad warning (yellow symbol) did not go off.
I thought I would deal with this when I have more time so have been driving around with the warning on for a few months. About a month ago I was at my mates garage and he had a little time so he removed the pad sensors and joined the pins together so as to complete the circuit so the warning should go off. This worked and the car said OK! Dropped the car down off the ramp, parked outside and when I jumped into the car about an hour later the warning was back again! Grr!!
A month has passed since and yesterday when I started the car, the warning suddenly disappeared and came up with OK! I was surprised! Turned the car on and off a few times and it still came up as OK. I thought maybe the car has to be driven a few miles before the warning goes off?
This morning however, the warning came back on!! It is annoying me now and was wondering if there was a simple solution?
I read that the warning can be because the brake fluid is low, but it is full. To take this out of the equation, we disconnected the sensor under the brake fluid reservoir and started the car car – this time “BRAKES” with a red symbol came up so the sensor is working and the amber brakes warning came back on when reconnected.
Car is going in next week to have my suspension overhaul done so I was thinking it might be a good idea to bleed the brakes – apparently the fluid should be changed every two years and I am not sure when it was last done. Could this finally solve it?
Any ideas?
Can it be coded out used Vagcom?
Anees
Any ideas?
Anees
