Page 1 of 2
20" Rotors on a sprint blue avant,pics anyone?
Posted: Thu Jun 13, 2013 9:49 am
by lengster1
Searched on here but cant find pics but im sure ive seen some ? If anyone has can they post up please?
Re: 20" Rotors on a sprint blue avant,pics anyone?
Posted: Thu Jun 13, 2013 12:29 pm
by MikeFish
Not seen them on bluey before. When I was looking for pics all I found was a white avant and 2 grey saloons. Obviously you can add mine to the list now.
Posted: Thu Jun 13, 2013 12:54 pm
by Rick_RS4
Just look at Jules car and squint
Posted: Thu Jun 13, 2013 3:31 pm
by Stoffle32
this one is on the OEM 20" Rs4 rims Image
Posted: Thu Jun 13, 2013 3:44 pm
by Cuppa
Not sure if they're 20", but this shows the rotors on a blue avant.
Posted: Thu Jun 13, 2013 3:45 pm
by Graeme4130
Stoffle32 wrote:this one is on the OEM 20" Rs4 rims Image
I think they're 19", no ?
Posted: Thu Jun 13, 2013 4:22 pm
by Stoffle32
no its my mates car, he has 20's and im sure this pic was taken when he had them installed with 5mm front spacers
Posted: Thu Jun 13, 2013 4:38 pm
by Graeme4130
Ok, actually now I look at it they to look a little bigger. I'll blame my small iPhone screen
Which model are they off to get 20's in that style ?
Posted: Thu Jun 13, 2013 4:59 pm
by doodlebug
C6 I suspect.
Posted: Thu Jun 13, 2013 5:25 pm
by MikeFish
Cuppa wrote:Not sure if they're 20", but this shows the rotors on a blue avant.
They look more like 19s and more importantly they don't have the right offset for an RS4 so are much less concave.
The RS5 Rotors (ET26) have the smallest amount of clearance on the front calipers. It is so close as I was turning the wheel (by hand) to check I actually thought it was going to clip them.
Posted: Thu Jun 13, 2013 9:52 pm
by MikeFish
Posted: Thu Jun 13, 2013 10:08 pm
by lengster1
Thanks mike,what adapters are required? cost?
Posted: Thu Jun 13, 2013 10:24 pm
by MikeFish
As the centre bore of the A5/RS5 is bigger than the size of the B7 one, a wheel made for the A5/RS5 will have a bigger hole in the centre of the wheel. This means you can still use an Rs5 wheel on a B7 but if you don't fit it dead centre you will get vibration at speed. But, if you get a spigot it basically makes the hole in the wheel a bit smaller so it is a snug fit on the RS4 hub.
Very cheap and easy to fit. You have 2 choices either the plastic versions or the metal ones. I bought both but the metal ones were too tight and would have needed hammeringto make them fit. I clearly didn't want to start hammering the wheel, so I ended up using the plastic ones. They fitted no problems.
Metal ones:
http://www.ebay.co.uk/itm/Conversion-sp ... 697wt_1161
They look better than the metal ones I bought, but I'd still stick with plastic.
Plastic:
http://www.ebay.co.uk/itm/SPIGOT-RINGS- ... 175wt_1399
As you can see the plastic ones are a fiver and they actually work really well.
FYI The RS4 centre bore size is 57.1mm and the Rs5 is 66.6mm.
Re: AW: 20" Rotors on a sprint blue avant,pics anyone?
Posted: Thu Jun 13, 2013 10:32 pm
by Spacecowboy
here some pics from a german board member...
sprint blue and rotors... epic !
Posted: Fri Jun 14, 2013 5:24 am
by MikeFish
I love my wheels!
