air con
Posted: Tue Jun 04, 2013 3:54 pm
hi every1. could any one tell me where the air con pressure sensor switch is located? as mine is showing a fault the gas is up to pressure. rs4 b7. many thanks
hi after been on the air con machine that told me the gas was full i put it on a diagnostics machine that brought up a air con pressure sensor fault.Markymark-RS4-B7 wrote:Hi rsslim,
Not an answer to your issue i'm afraid but i've just picked my RS4 up in the last few days and turned the Air-Con on for the first time and i too have a problem with mine (Not good as i'm on a monster road trip down to Cornwall). The econ mode light is on permanently and i'm unable to clear it, plus there is no air-conditioning because of it being stuck in that mode. I'm off to get it re-charged first thing this morning in hope that it's a lack of pressure that's being sensed that's the fault. If it's not that i'll be looking elsewhere to find the fault. How did you identify that your pressure sensor was at fault?
Hope you get an answer to your query...
rsslim wrote:hi after been on the air con machine that told me the gas was full i put it on a diagnostics machine that brought up a air con pressure sensor fault.Markymark-RS4-B7 wrote:Hi rsslim,
hope this helps
