It's been a busy few days.
First I stripped the rear shelf out to look at hiding the big crossover or possibly installing a couple of subs on it. More on this in a mo.
Then I stripped the interior trim on the bootlid and removed the number plate light holder, boot handle / lock to look at installing a camera.
Then I started my attempt at modding the R8 power steering fluid cap to fit the B7. More of that on my modding thread.
First off, once the back shelf was stripped and the Bose subwoofer removed, there was a nice perfectly round 9" cutout for a new subwoofer. There is a similar sized indentation on the other side of the shelf that could have been cut out to match. I wondered if my JL Audio 12W7 might drop in to this 9" hole. 2 of these on the back shelf could work out well. The amount of voume 2 of these could use in a box is probably about the same volume as is available in my boot so would effectively be mounted in a box rather than free air. I know this sub requires a cut out of 11" but I thought if I raised it slightly with an MDF ring it might just drop in. However, this was a complete no-no. Unless you have seen one of these in real life it is difficult to comprehend their sheer size (depth) and weight. It was so big it would not fit between the rear shelf and windscreen to even attempt to drop it in.
And 2 10's would just be drowned in that huge boot. 2 10" free air subs might go in and work reasonably but probably not a big improvement (if any) over the 18"er already in there. I did toy with the idea of getting another 18 to keep it company but not quite sure. I'm after quality rather than qunatity and another sub that size would detract from the quality and turn it into a bit of a boomer.
And once the rear shelf was off (which was a bit of a pain to remove) there wasn't any depth to the shelf at all. Thought I might hide the crossover in there but there just ins't any room. That Bose subwoofer is surprisingly thin!
So I figured I'd make the most of the shelf out and took the oppertunity to deaden the back shelf metal work and use the deadening material to block all the holes from both top and bottom.
Top finished:
Note there is a rectangular hole not covered near the rear. I had to leave this out as it is required to reconnect the centre brake light as the rear shelf is being installed. I have a pieve of deadening cut to size ready to stick from the underneath, I just ran out of time last night.
I forgot to take photos of the underside but I can do that later as it has to trim covering it up.
Also, it was quite annoying driving with the rear shelf out as I was usrprised to see it throw up an error for the centre brake light not working.
So then the shelf went back on (still haven't fully got the C-pillars back into the shelf yet, need to try it again at the weekend). With the backshelf out the bass turned really poor and low (level, not freqquency). Now it's been deadened it has really tightened the bass up (an 18" sub mounted free air would expect to not be tight but low and wallowy). Makes it sound like it has been installed in a sealed box now rather than a ported one. It is much punchier. This is not how I prefer my bass. Tight yes, but I prefer lower kick rather than upper punch but this can be sorted with a little eq. I will also deaden the boot lid once the camera and wires are in.
After I removed the number plat light / lock assembly I was ready to order a replacement part that incorproates a camera.
I had a few choices here. If I still had the RNS-E I might have gone for the Q7 equivalent as there is a kit for all the wiring already in existence. They only downside to this one is the extortionate price for the Audi bits and it would also mean losing the actual key lock as the Q7 doesn't have one here. Not a big deal as I don't think I have ever used it once but I don't like to lose functionality.
However, the option I went for is almost a like for like repalcement (with key lock) but the actual handle isa little narrower to make room for the camera. As it's an aftermarket jobbie the quility will not be as good as the Q7 one but this is much cheaper and has better functionality.
OEM B7 unit:
