Page 1 of 2
20" v 19" wheels debate
Posted: Thu Jan 17, 2013 11:39 pm
by sync24
All - I read with interest through old wheel discussions on the board and I've come across a couple of comments that the 20" rims are slightly less better handling than with 19" OEM's is this true?
I am currently looking at the best option for a wheel swap for my AVANT with SS+ - I love the Audi Q7 20's that dickytrickster runs. I am looking at 265x30x20 tyres with 5mm adapters from 5x112 to 5x130 as I dont want to go too far from OEM - looking at a tyre calculator they would be +6mm width from OEM
Now to source some Q7's & tyres
I will have a set of Tungsten 19" OEM's to sell in the spring once I've found some new rims, these are mint having only just been refurb'd by the original owner - stuffedbeaver and have no marks at all .....
Kev. :blackrs4:
Re: 20" v 19" wheels debate
Posted: Thu Jan 17, 2013 11:54 pm
by MikeFish
They are 10mm wider and 6mm higher. Why wouldn't you get 255/30/20 so they have the identical height/ rolling circumference? I had this discussion the other day but I'd expect a lower profile tyre to handle better not worse. However, the extra weight of the larger wheel is adding more I sprung weight which will have a negative effect. I think overall there will be little difference. Experience in the past however has shown me the lower profile tyre to handle better but that was long time ago and technology may have closed that gap now.
Posted: Thu Jan 17, 2013 11:56 pm
by MikeFish
Also, why do you want to change from 5x112 to 5x130?
Posted: Thu Jan 17, 2013 11:58 pm
by MikeFish
If you want my advice about wheels and spacers you need to find the wheel you want first. Then once you know the width and offset of it, you can decide how much of a spacer you need to allow caliper clearance and push the rims out as far as you want them.
Posted: Fri Jan 18, 2013 12:04 am
by sync24
Hey Mike, I quote dickytrickster who says "The q7 stud pattern is different to the rs4 so you have top run adapters. I run 15mm adapters from 5x112 to 5x130 and the wheels fill the arches great"
I'd be happy to run 255x30x20 tyres - I'm watching a set of Q7's now -The only reason I said run 265's is that the rim size is 20x10 where OEM is 19x9 - I thought it better to run a slightly wider tyre to avoid stretching.
I am a n00b at this so may be talkin' b*ll0x!
Kev.
Posted: Fri Jan 18, 2013 12:16 am
by MikeFish
No that makes sense mate, I didn't realise y were dead set on getting that particular wheel. If Tanya's the one you want then go for it. Dicky says he has a 15mm spacer but you said 5mm. Was that a typo?
Posted: Fri Jan 18, 2013 1:01 am
by sync24
MikeFish wrote:Was that a typo?
Yep fat finger syndrome!
Posted: Fri Jan 18, 2013 10:06 am
by Brooner
Here's a handy link to calculate the alloy tyre combonation
http://www.alloywheelworld.co.uk/page.php/tyrecalc.html
Posted: Thu Jan 24, 2013 7:36 pm
by slowmonkey
I don't find the handling any different on the 20"'s but you might notice the ride comfort with the lower profile tyre. I chucked my drc out and put coils on at the same time so my ride comfort changed quite dramatically anyway !
Posted: Fri Jan 25, 2013 7:33 pm
by dazie00
Are these the 20" style wheel u want, if so ill be selling these soon , I had 10 on rear and 11 on front spacers
Posted: Fri Jan 25, 2013 8:47 pm
by MikeFish
dazie00 wrote:Are these the 20" style wheel u want, if so ill be selling these soon , I had 10 on rear and 11 on front spacers
Dazie, I assume you meant 10mm and 11mm spacers and not 10" and 11" wheels!?
Posted: Fri Jan 25, 2013 9:32 pm
by dazie00
That's right mike ,20"x 9.5 I think Rs 6 alloys, spacers 10 mm rear 11 mm front , with tyre pressure sensors and 2 michillin 265/30/20 in as new condition and can supply 2 brand new as well.all long bolts and locking wheel nuts as well
Posted: Fri Jan 25, 2013 9:37 pm
by u2usual
dazie00 wrote:That's right mike ,20"x 9.5 I think Rs 6 alloys, spacers 10 mm rear 11 mm front , with tyre pressure sensors and 2 michillin 265/30/20 in as new condition and can supply 2 brand new as well.all long bolts and locking wheel nuts as well
Can you PM me how much you want for the wheels without the spacers and just 2 tires? Thanks!
Posted: Sat Jan 26, 2013 12:55 am
by sync24
Nope - I am looking for some of these - but still not sure about tyre sizes/spacers/adpators as they are 20x10
Posted: Sat Jan 26, 2013 1:04 am
by ad2330
^ just totally depends on the offset.
