new rs4 with problems , help please
Eddie555
Re: new rs4 with problems , help please
Post by Eddie555 » Fri Jul 07, 2017 6:45 pm
Any relay is a very simple switch controlled by a constant positive or a negative pulse. I would be using a set of multi meters and checking whether you have these present and stable. If they are stable then it's a faulty relay. If not then the problem is the source of where the pulse is sent from.
Current ride’s
Previous rides
white.akita
Post by white.akita » Fri Jul 07, 2017 6:56 pm
is it supposed to constantly and quickly switch on and off when doing an output test ?
Eddie555
Post by Eddie555 » Fri Jul 07, 2017 7:09 pm
Take a picture of the relay with the terminals showing and post it up.
Current ride’s
Previous rides
rs user
Post by rs user » Fri Jul 07, 2017 7:12 pm
the two bigger relays will do the same task-swap them around and see if fault moves...
on my car somebody had replaced the relay previously[first one] with an item from the antiques roadshow
white.akita
Post by white.akita » Fri Jul 07, 2017 8:57 pm
Anyone got a pic of where these relays are ?
Sent from my SM-G935F using Tapatalk
white.akita
Post by white.akita » Fri Jul 07, 2017 9:34 pm
just found this thread viewtopic.php?t=88507&start=45
looks like my exact problem.
£15 relay and it should be fixed, pleased i didnt take it to a garage to be charged £££££
white.akita
Post by white.akita » Fri Jul 07, 2017 10:12 pm
ok well ! i have just been outside and removed the scuttle panel and lifted the ecu but there are no relays under there, anyone know where the relays are for the vacuum system on a rs4 ?
rs user
Post by rs user » Fri Jul 07, 2017 10:36 pm
you have to remove wipers,remove scuttle tray that wiper spindles bolt through,remove the big flat cover under the bonnet that runs along the back of the bay
remove ecu cover at drivers side after this[about 5 torx iirc] unclip ecu,relays are beneath
white.akita
Post by white.akita » Fri Jul 07, 2017 10:45 pm
thanks again arthur
white.akita
Post by white.akita » Sat Jul 08, 2017 9:23 am
That's the relay, looks burnt ??ImageImage
white.akita
Post by white.akita » Sat Jul 08, 2017 9:51 am
The other relay looks the same, I've swapped them over but it's exactly the same
rs user
Post by rs user » Sat Jul 08, 2017 11:29 am
thats not your issue then
the relay will be cycling during the test to let you monitor its function on the car...
imho your issue is either stuck runners/valve under manifold
possibly lack of vacuum
i replaced all the relays[3] was about 20 odd quid-i think the 614 has been updated too...
white.akita
Post by white.akita » Sat Jul 08, 2017 11:29 am
Bought a new relay and swapped them all over and still the same :(
white.akita
Post by white.akita » Sat Jul 08, 2017 11:31 am
Anyone know why all of my vacuum related output tests are failing ? There is vacuum to the pipes that run along the front of the engine and to the pipes that runs to the exhaust.
white.akita
Post by white.akita » Sat Jul 08, 2017 12:28 pm
done a full scan.
Saturday,08,July,2017,12:08:13:39744
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8 x64
VCDS Version: 17.1.3.0 (x64)
Data version: 20170203 DS267.2
www.Ross-Tech.com
VIN: WUAZZZ License Plate: RS4 FAULT LIST
Mileage: 171540km-106590mi Repair Order:
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WUAZZZ Mileage: 171540km-106590miles
Address 01: Engine Labels: 079-910-560-BNS1.lbl
Part No SW: 8E1 910 560 HW: 8E1 907 560
Component: 4.2L V8/4V FSI ª0090
Revision: 57H13--- Serial number: XXXXXXXXXXXXXX
Coding: 01040003180F0160
Shop #: WSC 00045 210 90248
VCID: 63C274CEA2CEF85994-8036
4 Faults Found:
008198 - Intake Manifold Flap; Bank 1
P2006 - 008 - Stuck Closed - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 171540 km
Time Indication: 0
Freeze Frame:
RPM: 927 /min
Load: 39.6 %
Speed: 0.0 km/h
Temperature: 37.0°C
Temperature: 26.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 11.430 V
008196 - Intake Manifold Flap; Bank 1
P2004 - 002 - Stuck Open - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 171540 km
Time Indication: 0
005495 - Right Engine Mount Solenoid Valve (N145)
P1577 - 004 - Open Circuit
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 171540 km
Time Indication: 0
Freeze Frame:
RPM: 206 /min
Load: 89.8 %
Speed: 0.0 km/h
Temperature: 39.0°C
Temperature: 27.0°C
Voltage: 10.160 V
006435 - Please Check DTC Memory of ECU Number 2
P1923 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 171540 km
Time Indication: 0
Readiness: 0110 1101
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 G HW: 8E0 614 517 BD
Component: ESP8 quattro H06 0150
Revision: 00000000 Serial number: 00000000000000
Coding: 0004533
Shop #: WSC 06335 000 00000
VCID: 2B52DCEE8A9E70196C-807E
No fault code found.
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BK
Component: A4 Klimaautomat 2833
Coding: 00000
Shop #: WSC 00000
VCID: 6BD21CEE191EB0192C-513C
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul ECE 0907
Coding: 00021
Shop #: WSC 06335
VCID: 3D76E2B637EAEEA9C2-4B18
Address 11: Engine II Labels: 079-910-560-BNS2.lbl
2 Faults Found:
008197 - Intake Manifold Flap; Bank 2
P2005 - 002 - Stuck Open - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 171540 km
Time Indication: 0
Freeze Frame:
RPM: 769 /min
Load: 44.7 %
Speed: 0.0 km/h
Temperature: 38.0°C
Temperature: 25.0°C
Voltage: 13.335 V
005491 - Left Engine Mount Solenoid Valve (N144)
P1573 - 004 - Open Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 171540 km
Time Indication: 0
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H12 3730
Revision: 91H12373 Serial number: 0036M0G41XUT
Coding: 0430612
VCID: 3B72ECAE7AFEE099FC-806E
Subsystem 1 - Serial number: 6332DRB403CD110FS
Subsystem 2 - Serial number: 6342DRB4041887A7T
Subsystem 3 - Serial number: 6352ARB401B3B87D-
Subsystem 4 - Serial number: 6362ARB401B69D14S
Subsystem 5 - Serial number: 63729RB401C36225E
Subsystem 6 - Serial number: 63829RB401C3871AQ
Address 16: Steering wheel Labels: 8E0-953-549-T.lbl
Part No: 8E0 953 549 T
Component: Lenksáulenmodul 0301
Coding: 16021
Shop #: WSC 06335
VCID: 4480975254009F618D-4B00
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 981 R HW: 8E0 920 981 R
Component: KOMBI+WFS 4 H14 0050
Revision: 0050 Serial number: 00000000000000
Coding: 0023411
Shop #: WSC 37488 001 1048576
VCID: 3C70EFB27CF0E7A1F5-515A
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0023411
Address 46: Central Conv. Labels: 8E0-959-433-MAX.clb
Part No: 8E0 959 433 CH
Component: Komfortgerát T3B 4135
Coding: 06895
Shop #: WSC 06335
VCID: 79FE36A663421289AE-4B18
Subsystem 1 - Part No: 8E2959802F
Component: Tõrsteuer.FS BRM 0606
Subsystem 2 - Part No: 8E2959801F
Component: Tõrsteuer.BF BRM 0606
Subsystem 3 - Part No: 8E0959801E
Component: Tõrsteuer.HL BRM 0606
Subsystem 4 - Part No: 8E0959802E
Component: Tõrsteuer.HR BRM 0606
6 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
00956 - Key 2
35-10 - - - Intermittent
01334 - Door Control Module; Rear Right (J389)
53-10 - Supply Voltage Too Low - Intermittent
00935 - Electric Window Motor; Rear Right (V27)
62-10 - No or Incorrect Adjustment - Intermittent
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 F
Component: Dynamische LWR H02 0010
Revision: 00000001 Serial number:
Coding: 0000005
VCID: 3D76E2B664EAEEA9C2-8068
End-------------------------(Elapsed Time: 06:24)--------------------------
Users browsing this forum: No registered users and 332 guests
