new rs4 with problems , help please
white.akita
Re: new rs4 with problems , help please
Post by white.akita » Wed Jul 05, 2017 10:37 am
I'm in bishop auckland north east
Sent from my SM-G935F using Tapatalk
white.akita
Post by white.akita » Wed Jul 05, 2017 10:38 am
There is no vacuum whatsoever com8ng from this unit picturedImage
white.akita
Post by white.akita » Wed Jul 05, 2017 10:39 am
This pipe does have strong vacuum, it's on the UK passenger side next to the dipstickImage
jonytek
Post by jonytek » Wed Jul 05, 2017 10:57 am
You need to take it in to be checked out mate. You say the vacuum hoses have been removed from the exhaust valves. make sure they are plugged up. They will most probably be pushed back in under the bumper.
BUILD THREAD
IG: @bad_rs_4
white.akita
Post by white.akita » Wed Jul 05, 2017 11:20 am
I can't see any pipes for the exhaust boxes at all.
That is under the airbox again with no vacuum at all going to it.
I'd really like to be able to fix it myself, if anyone can help with this ?Image
jonytek
Post by jonytek » Wed Jul 05, 2017 12:00 pm
The hoses are disconnected from the back boxes. Take a look under the rear bumper.
http://www.audizine.com/forum/showthrea ... s-(How-To)
BUILD THREAD
IG: @bad_rs_4
white.akita
Post by white.akita » Wed Jul 05, 2017 12:09 pm
I found green hoses disconnected from the rear exhaust boxes.
With the engine running I could feel no vacuum in the pipes.
I have blocked the end of the pipes off but it's made no difference.
white.akita
Post by white.akita » Wed Jul 05, 2017 12:11 pm
Why would there be zero vacuum coming from this unit ? I pulled the pipe off as pictured and there's no vacuum with the car running at all, with it plugged in and the car idling for 5 mins then turned off I immediately removed the pipe pictured and absolutely nothing. No hissing nothing.Image
jonytek
Post by jonytek » Wed Jul 05, 2017 12:20 pm
Sounds like you need a new engine mate.
BUILD THREAD
IG: @bad_rs_4
white.akita
Post by white.akita » Wed Jul 05, 2017 1:19 pm
Doubt it.
Anyone know why that valve would have no vacuum ?
white.akita
Post by white.akita » Wed Jul 05, 2017 1:42 pm
The electrical connector next to the pipe has had some crap repair job done on it in the past. What does that do ? Would it stop vacuum ?
rs user
Post by rs user » Wed Jul 05, 2017 1:44 pm
dont pull pipes off here and there with it running you will flag all sorts of issues that will be multiple red herrings
get Vagcom and clear all faults-check what comes back after they are cleared-i have a snap on solus -its very good in expert mode on these too-but vag-com is better
you need the later Vag Com cable too-not the cheap 5 quid one-a hex-can
white.akita
Post by white.akita » Wed Jul 05, 2017 2:17 pm
I pulled them off to see it there was vacuum with it running which there is not.
I did then delete all fault codes, the only 2 that keep coming back are p2004 and p2005
white.akita
Post by white.akita » Wed Jul 05, 2017 2:20 pm
Them fault codes basically say there is no vacuum going to the inlet flaps. There is no vacuum whatsoever at the junction box ive pictured. Anyone know why ?
MrHilario
Post by MrHilario » Wed Jul 05, 2017 2:48 pm
1.4 Fiesta (Silver)
2.8 VW Bora V6 4motion (Blue)
4.2 Audi RS4 B7 Avant (Black)
Users browsing this forum: No registered users and 331 guests
