demon8991
Post
by demon8991 » Wed Aug 16, 2023 12:48 am
TRS842 wrote: ↑Mon Aug 14, 2023 12:05 am
@demon8991 - I'm about to do the exact same setup install on my 2008 B7 Sedan.
Keen to hear from you on the ride of the H&R springs. Do they ride as harsh as when the DRC are in sport mode or standard setting?
Appreciate any info you could share here.
@TRS842 - Hey mate, the ride is so close to DRC, if I am splitting hairs bumps are ever so sligthly more noticeable but there is very little in it.
Handling through the twisties is better and opting for the H&R lowering springs (lowers by 15-20mm) gets the ride height bang on all round in my view.
R8 V10 Gen 1 • Phantom Black • Coupe • Gated Manual • Quicksilver Valveless Exhaust • REP RamAir Filters • CF Interior/Engine/Side Blades • Wireless Apple CarPlay
RS4 B7 • Phantom Black • Centre Resonator Delete • Wireless Apple CarPlay
SQ5 TDI • Ibis White • Fully Optioned • Wireless Apple CarPlay
TRS842
Post
by TRS842 » Wed Aug 16, 2023 2:15 am
Hey Matey,
Thanks so much for getting back to me.
Can you confirm if the ride is similar to the DRC when 'S' mode is on or off?
I find in 'S' mode its rather harsh.
Hoping the H&R ride is similar in non 'S' mode if that all makes sense?
Cheers,
Trent
12th
Post
by 12th » Wed Aug 16, 2023 8:13 am
The ride is similar, but there's one area where it's noticeably worse - expansion joints. More of a thump both felt and heard. The front is better tied down so it's a worthwhile tradeoff, but it isn't as good or better in absolutely all areas.
Sprint Blue B7 RS4 Saloon with MRC tweakery.
TRS842
Post
by TRS842 » Fri Aug 18, 2023 2:34 am
12th wrote: ↑Wed Aug 16, 2023 8:13 am
Similar to S or non S mode?
Keeping in mind the ride is firmer on damper settings on DRC when S mode is activated.
Appreciate anyone who can help answer this.
12th
Post
by 12th » Fri Aug 18, 2023 8:19 am
TRS842 wrote: ↑Fri Aug 18, 2023 2:34 am
My understanding is that DRC is not altered in sport mode - just the mapping, exhaust and bolsters. My DRC lasted from purchase in 2007 until last year, so I've plenty of experience of it. That said, I use the car in S mode all the time, and that's where I am drawing my comparison. If you believe the car is more compliant in non-S mode, you'll definitely notice expansion joints more.
QuRace
Post
by QuRace » Fri Aug 18, 2023 9:04 am
12th wrote: ↑Fri Aug 18, 2023 8:19 am
That was my understanding also (and I was just going to comment about it).
The DRC system is purely mechanical. It's behaviour cannot be modified by some software/electrical setting.
delroyx
Post
by delroyx » Fri Aug 18, 2023 11:59 am
The 'S' or 'Sport' button does nothing to the suspension. It activates the seat bolsters (if not disabled), throttle response/map & exhaust flaps.
Attached is a screenshot from the brochure.
demon8991
Post
by demon8991 » Sat Aug 19, 2023 1:48 am
Yeah as others have said sport mode does not change the ride with DRC.
TRS842
Post
by TRS842 » Sun Aug 20, 2023 4:25 am
Roger that and appreciated.
My current DRC's are leaking and suspect they are more or less knackered.
Koni's and H&R setup going in tomorrow. Any other bushes or mounts others would suggest replacing whilst the work is being done?
Will post pictures after install.
demon8991
Post
by demon8991 » Sun Aug 20, 2023 11:22 pm
I would definitely get the bump stops done if they are original or old.
One regret with mine is not doing those.
TRS842
Post
by TRS842 » Mon Aug 21, 2023 6:45 am
demon8991 wrote: ↑Sun Aug 20, 2023 11:22 pm
Absolutely and have new ones going in.
demon8991
Post
by demon8991 » Mon Aug 21, 2023 11:10 pm
Awesome mate, good to see another one over here in Australia.
I am guessing you got the shocks sent to you from Shocker Boy in the UK?
TRS842
Post
by TRS842 » Tue Aug 22, 2023 12:06 am
demon8991 wrote: ↑Mon Aug 21, 2023 11:10 pm
Thanks, and yes rather excited to see how these do.
I ordered them from Steve at CRS.
The H&R springs I sourced from TunerShop.
Should be all wrapped up by midweek as I am also replacing the front pads on the ceramics, so I'll post some pictures once completed.
demon8991
Post
by demon8991 » Tue Aug 22, 2023 5:42 am
TRS842 wrote: ↑Tue Aug 22, 2023 12:06 am
Yep, Steve is the same guy.
Did you opt for the lowering springs or the standard ones?
Oh nice, you have ceramics!!! Keen to see photos.
TRS842
Post
by TRS842 » Tue Aug 22, 2023 11:54 pm
Opted for the H&R lowering springs. Although concerned it may be a tad too low in the rear.
Considering switching to KW HAS springs to allow me to set the perfect ride height.
Users browsing this forum: dan32v, Google [Bot], ozworth and 95 guests
