Steering upright! Bitch bolts! Wheel bearings, control arms
Ranger Rico
Post by Ranger Rico » Thu Aug 25, 2022 3:48 pm
Hello RS4ers,
So split bushes on the control arms brought up an advisory so i decided to change them out.
Drivers side pinch bolt came out after an hour or so but the inevitable happened on the Near side, bolt sheared, 4 hrs of heating and hitting then stupidly using a G clamp to try and force the pin out cause the upright to crack.
Never mind :(
The question is to change out the upright ill have to almost certainly get a new Wheel bearing as they are pressed in yeah?
If so should i change out both wheel bearings as a good practice? Theres no issues with either at the moment
Or is it worth trying to put the old bearing into the new upright hub?
Shes done 78K.
Any Advice or ridicule accepted
Richie
stuartbarriskell
Re: Steering upright! Bitch bolts! Wheel bearings, control arms
Post by stuartbarriskell » Thu Aug 25, 2022 5:49 pm
New bearing..always.
Sent from my SM-G998B using Tapatalk
Current stable: B8 RS4.
13 BMW HP4 Track/Road
21 BMW S1000RR Sold
04 ZX 10R Sold
MV Agusta Reparto Corse Sold
GoneB7 RS4
Gone B7 S4
Gone 1.8 T
Gone A3
Covkiller
Post by Covkiller » Tue Feb 21, 2023 8:31 am
No, you're wasting time and money. If there is no play and noise leave it be.
Ranger Rico
Post by Ranger Rico » Fri Feb 24, 2023 9:03 am
I put a new bearing in on the new upright, but you're probably right as there was nowt wrong with the old bearing.
coffey555
Post by coffey555 » Fri Feb 24, 2023 11:09 am
Keep the old one as a spare! Probably good for another 100k!!!
Misano Red RS4 B7 Avant
Sneakybutcher
Post by Sneakybutcher » Tue Jul 25, 2023 10:06 am
What control arms did you go for? I need to do my uppers on both sides and tossing up between Meyle or Lemforder, I can get a full set of Meyle for the price of just the uppers in Lemforder.
rs user
Post by rs user » Wed Jul 26, 2023 11:24 pm
I used meyle hd were brilliant
watch out for the low torque setting for the new pinch bolt...also only tighten the arm bolts when weight of car on strut-there are exact measurements on the web
Ranger Rico
Post by Ranger Rico » Thu Jul 27, 2023 8:06 am
i got the parts from Ebay
Meyle link set
https://www.ebay.co.uk/itm/203304891788
Steering knuckle
https://www.ebay.co.uk/itm/334264227361
and as rs user says i tightened the arm bolts with the car down but access was very limited, i couldnt get a torq wrench in so i used my best judgement!
Users browsing this forum: Baidu [Spider], Google Adsense [Bot], Majestic-12 [Bot] and 116 guests
