Mass air flow p0101 help!!!!
Dannorton
Post by Dannorton » Sun Jun 14, 2015 5:08 pm
Hi guys, engine management light and traction light came on this morning, I have Vag Com so plugged it in and got p0101 error. I only know how to use the basics in Vag Com so don't know how to look further into it!
I'm just wondering if any of you guys have come across this error and if it is the maf and not something else before I go and spend £100 on a new one!
Cheers! This is what I got below!
Sunday,14,June,2015,16:39:39:65217
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: License Plate: LF56 DGE
Address 01: Engine Labels: 079-910-560-BNS1.lbl
Control Module Part Number: 8E1 910 560 HW: 8E1 907 560
Component and/or Version: 4.2L V8/4V FSI ª0090
Software Coding: 010C0003180F0160
Work Shop Code: WSC 00191 264 15243
VCID: E3CF37CC22ABF906691-80B6
1 Fault Found:
000257 - Mass Air Flow Sensor (G70)
P0101 - 004 - Implausible Signal
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 123431 km
Time Indication: 0
Freeze Frame:
RPM: 917 /min
Load: 20.0 %
Speed: 0.0 km/h
Temperature: 96.0°C
Temperature: 48.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 11.938 V
Readiness: 0110 1101
JCviggen
Re: Mass air flow p0101 help!!!!
Post by JCviggen » Sun Jun 14, 2015 6:07 pm
Yeah, that's going to take a new MAF sensor. Easy 2 minute fix, and pretty cheap as far as RS faults go.
981 Cayman GTS Gray/Orange.
My youtube
R1RS4
Post by R1RS4 » Sun Jun 14, 2015 8:17 pm
You could clear DCT's first to see if it comes back 10 min job
If you change the MAF sensor they recommend changing the main air filter, unless you know it to be good that is ie contaminants could have come through the air filter
RS4 B7 Avant,2007
Dannorton
Post by Dannorton » Sun Jun 14, 2015 9:57 pm
Yes I've tried cleaning it with maf cleaner and still no joy, also the code comes back as soon as the car fires up!
I know it's not always what vag coms says and can be other sensors causing the problem!
I'll get a new maf sorted in then morning then cheers guys!
rs4dave
Post by rs4dave » Mon Oct 10, 2022 6:25 am
Did this ever get sorted ?
delroyx
Post by delroyx » Mon Oct 10, 2022 4:26 pm
Bit of an old thread revival.
I had this fairly recently, well March. I was expecting to need to fork out for a new one but I tried cleaning the MAF sensor with alcohol spray as I didn't have much to loose. Gave it a thorough soaking, blasted with compressed air then another soaking. Left it inside to dry overnight (probably don't need that long as the alcohol evaporates very quickly).
Plugged back in & cleared the fault. Touch wood not come back. A few ignition cycles might clear it too if you don't have VCDS?
rs4dave
Post by rs4dave » Tue Oct 11, 2022 10:34 am
No matter what I do the problem keeps coming back, cleaning the maf doesnt fix it. Replacing it fixes the issue straight away, but it keeps happening on mine. Not sure what to do.
OliverT
Post by OliverT » Wed Oct 19, 2022 8:53 am
A similar situation with you. I am also looking for a solution
rs4dave
Post by rs4dave » Sat Oct 29, 2022 11:16 pm
Is your car modified at all and under what circumstances does it fail ?
