Glovebox Fridge retrofit
fairzy
Post by fairzy » Wed Jan 01, 2020 5:10 pm
Has anybody retrofitted a fridge / cooling box to their B7? I've got a second hand one but it's currently installed in an old glovebox and apart from using brute force to remove I can't figure out how to get it out.
There are 3 x torx screws along the bottom, which I've undone, and that's as far as I've got....
Can anyone help?
Sent from my Pixel 3 XL using Tapatalk
Quango86
Re: Glovebox Fridge retrofit
Post by Quango86 » Wed Jan 01, 2020 5:19 pm
Did you win this one on ebay? I thought about buying it aswell
B7 saloon, koni Shocks and h and r springs, h and r spacers 8mm f+r, milltek non res with valves, milltek d/ps, k and n filter, full mrc carbon clean, mrc stage 2 with l/c and f/s 456bhp 522nm.
fairzy
Post by fairzy » Wed Jan 01, 2020 5:37 pm
Quango86 wrote:Did you win this one on ebay? I thought about buying it aswell
Yes - think it's the same one .
Kenny147
Post by Kenny147 » Wed Jan 01, 2020 10:05 pm
Open the cooler door and at the back there may be the inlet plug from the A/C. Unscrew and remove that and the whole unit should slide out, if you’ve removed the 3 T8 screws.
fairzy
Post by fairzy » Wed Jan 01, 2020 10:20 pm
Kenny147 wrote:Open the cooler door and at the back there may be the inlet plug from the A/C. Unscrew and remove that and the whole unit should slide out, if you’ve removed the 3 T8 screws.
Thanks Kenny - have removed the inlet plug and the 3 x screws so just keep pulling?
Kenny147
Post by Kenny147 » Wed Jan 01, 2020 10:22 pm
Forgot.....there are two clips about 4 cm in from each end at the top. You’ll probably need to “lift” the glove box shelf above the cooler, up a bit to get it out.
fairzy
Post by fairzy » Wed Jan 01, 2020 10:47 pm
Kenny147 wrote:Forgot.....there are two clips about 4 cm in from each end at the top. You’ll probably need to “lift” the glove box shelf above the cooler, up a bit to get it out.
You're a legend. Thanks mate
Kenny147
Post by Kenny147 » Wed Jan 01, 2020 11:00 pm
No worries, google “ECS glove box cooler kit” and you’ll find instructions on how to fit the cooler pipe.
Easier if I just link it. See below.
Kenny147
Post by Kenny147 » Wed Jan 01, 2020 11:13 pm
fairzy
Post by fairzy » Wed Jan 01, 2020 11:18 pm
Thank you again for this. Just released the cooler by prying up the 'shelf' which would normally hold the CD changer and it came out very easily.
For anyone else looking at doing this remove the 3 Torx screws, unscrew the vent at the back (inside the cooler) and then lift up the shelf with a trim removal took to release these 2 catches and it'll slide out.
Kenny147
Post by Kenny147 » Thu Jan 02, 2020 12:09 am
:thumbs:
demon8991
Post by demon8991 » Fri Jan 10, 2020 6:00 pm
Out of interest does the AC have to be on for this to work?
Also how cold does it actually get?
R8 V10 Gen 1 • Phantom Black • Coupe • Gated Manual • Quicksilver Valveless Exhaust • REP RamAir Filters • CF Interior/Engine/Side Blades • Wireless Apple CarPlay
RS4 B7 • Phantom Black • Centre Resonator Delete • Wireless Apple CarPlay
SQ5 TDI • Ibis White • Fully Optioned • Wireless Apple CarPlay
fairzy
Post by fairzy » Fri Jan 10, 2020 6:20 pm
I didn't expect much if it but so far I'm very impressed. My air con is on all the time, well temp is set on auto, and it's damn cold, even with eco mode on.
stephenhawking
Post by stephenhawking » Fri Aug 05, 2022 12:58 pm
Open the cooler door and at the back there may be the for more best beer guide here and inlet plug from the A/C. Unscrew and remove that and the whole unit should slide out, if you’ve removed the 3 T8 screws.
Unfortunately, there are two clips at the top, one around 4 cm from each end. To remove the cooler, you'll likely need to "raise" the shelf in the glove box above it a little bit.
docurley
Post by docurley » Wed Aug 10, 2022 7:47 pm
I had one in my first RS and thought it was a waste of space to be honest.
Users browsing this forum: Limited100, Majestic-12 [Bot] and 98 guests
