Hi,
Anyone got any experience with Coding out TPMS via VCDS ? its my first RS4 B7 and whilst the car is fantastic .....the TPMS is driving me nuts.
VCDS code out TPMS
Re: VCDS code out TPMS
Hi,
I've just done this using OBDEleven.
These posts might help:
- viewtopic.php?f=35&t=108002&p=651686&hi ... 12#p651686
- https://www.audiworld.com/forums/rs4-b7 ... 7-2950925/
From memory, you need to go into the instrument cluster and reduce the channel with the TPMS by 512.
Thanks highrise, will take a look
Quick update : For anyone wanting to remove TPMS via VCDS i followed the instructions below and it worked for me.
To disable TPMS – go to 17 – Instruments and then go to the Adaptation module.
In the Adaptation module, switch to Channel 061 then subtract 512 from the number that is displayed. Save and Exit.
