I couldn't find an answer to this. What is the recommended service interval for the belt & tensioner?
I don't think mine has ever been done so going to get the belt & tensioner changed. Are there any other pulleys that need changing at the same time?
Thanks in advance
Auxiliary/Serpentine Belt
Re: Auxiliary/Serpentine Belt
Our maintenance schedule in the USA says to check at 15, 55, 95k miles and replace as needed, tbh you are doing the right thing if you plan to replace as these are 13-15 year old parts depending on the year your car is.delroyx wrote:I couldn't find an answer to this. What is the recommended service interval for the belt & tensioner?
Thanks in advance
As I recall there is 1 idler pulley too that you should change at the same time, part number was/is 079903341D but you will need to check this.
Sent from my iPhone using Tapatalk Pro
Brilliant thanks @AA_954. So just the belt, tensioner & the extra pulley.
Anyone able to confirm part numbers?
