TB was cleaned when I had the IM off for carbon clean, (should of done the injectors at the same time) 1 way valve under intake was changed and new IM gaskets usedAA_954 wrote: ↑Mon Nov 09, 2020 5:22 amThe readings you mention seem ok, adaptation is something you could to do but honestly I would not underestimate the injectors specially with the mileage you have, flap screws and faulty injectors are the main reasons behind these engines getting blown. A faulty TB would give a code and you would notice in some cases sudden jumps in idle moving, you could also peep down the hose between the MAF and TB and see if the TB flap has any dirt buildup. As someone else mentioned hpfp could be a possibility but you haven’t mentioned anything about misfiresRS4RAB wrote:High pressure was logged and at 7000rpm to 8000 car was specifying 114.99, actual readings were anywhere from 113-119AA_954 wrote: ↑Sun Nov 08, 2020 3:27 amDefinately change the injectors.
Did you log Low pressure fuel and High pressure in the pulls?
For reference I see a peak of 162grs maf read at ~7800, give it a clean first to see, I assume the air filter is new or at least recently cleaned?
The lowest I get at WOT with lpfp is 3.8 and hpfp specified and actual at around ~120
Sent from my iPhone using Tapatalk Pro
At this pull i was reading 150grs on the MAF
Didn't have low pressure logged but had group 106 which is electrical fuel pump and between 7-8k this was between 49 and 52, think that is a percentage
It does start to pull timing at around 5k rpm? and other times randomly at low RPM?
Have taken the air filter out this afternoon and it was filthy, cleaned now and once dry i will re oil with the spray from the cleaning kit, will clean the MAF also as looks a bit dirty
You mentioned AMD tuned so are you in the US? AMD tunes here as I recall are done by UM, about the air filter just clean it but don’t oil it, theres different views but most of the owners I know including myself will go with a non-oiled filter.
When doing this I found a split in the vacuum line that runs across the front of the engine bay that goes to the air box flap, thought at this point that was my issue! Also one of the arms that actuate the flap rods had a fair amount of slack in it, I was removing the flaps and screws but the actuators were going to be left in so they didn’t need mapping out so I replaced the worn part
As far as misfires go VCDS shows nothing as the mapping seems to disable this data, not sure if getting the car flashed back to stock is the first thing to do or change injectors!
I’m in the UK, AMD are in Essex and believe this is where the car was mapped by the previous owner
