Exhaust Issue
cjt2020
Exhaust Issue
Post by cjt2020 » Wed Jun 10, 2020 4:09 pm
Hi all
Any ideas if this broken connection to actuator can be fixed or do I need a new back box ? It’s stopping exhaust flaps from working properly
Many Thanks, Chris
Red roof
Re: Exhaust Issue
Post by Red roof » Sun Jun 21, 2020 9:35 pm
Same thing happened to me when trying to free up seized actuators. Forced me into the decision to blank the lines off and have the flaps open constantly. The exhaust note is changed a little, it’s slightly more noticeable but that’s about all the difference.
I’ll put it back to standard when I need a new exhaust.
Sent from my iPad using Tapatalk Pro
cjt2020
Re: Exhaust Issue
Post by cjt2020 » Sun Jun 21, 2020 10:04 pm
Thanks, mine are jammed open and it’s running fine without error just a bit louder as you say. How did you blank off lines?
coffey555
Re: Exhaust Issue
Post by coffey555 » Sun Jun 21, 2020 10:17 pm
Stick a golf tee up each of the vaccum hoses. Or a wood screw.
Misano Red RS4 B7 Avant
James1984
Re: Exhaust Issue
Post by James1984 » Sun Jun 21, 2020 11:33 pm
I tapped a thread in mine and screwed in a mountain bike brake bleed nipple, holding out so far
cjt2020
Re: Exhaust Issue
Post by cjt2020 » Mon Jun 22, 2020 7:09 am
Brilliant, thanks both
Red roof
Re: Exhaust Issue
Post by Red roof » Mon Jun 22, 2020 7:36 am
M6 bolt with some lo tote thread sealant then cable tied the hose to the bumper bracket.
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 358 guests
