H & R 8mm Hubcentric Spacers - Where?
DavidRS4
Post by DavidRS4 » Wed Apr 01, 2020 2:28 pm
As above, need 2 x Hubcentric 8mm spacers. Can’t seem to find them anywhere apart from on E Bay and the seller isn’t answering my question. Need silver coloured, not black.
Can anyone help?
suurenmoinen
Re: H & R 8mm Hubcentric Spacers - Where?
Post by suurenmoinen » Thu Apr 02, 2020 11:39 am
I have the same problem. Have they stopped making them?
RS4eddie
Post by RS4eddie » Thu Apr 02, 2020 4:03 pm
2007 RS4 | Phantom Black | Milltek'ed | LED DRL'ed | H&R wheel spaced | 034 Density Line control armed | Hotchkis F + R Sway Barred | K&N Filtered | Ziza lit | Lamix-ed | Passport 9500ix hardwired | Dension Pro BT'ed | StopTech Brake Padded
DavidRS4
Post by DavidRS4 » Thu Apr 02, 2020 5:23 pm
You guys check Achtuning yet?
https://www.achtuning.com/h-r-1655572-5 ... olkswagen/
They aren’t Hubcentric.
DavidRS4
Post by DavidRS4 » Thu Apr 02, 2020 5:24 pm
Look on E Bay. There’s a seller on there. Picture has a set in silver and black as the main picture. Sent them a message and now ordered a set from them in silver. Good price too
RS4eddie
Post by RS4eddie » Thu Apr 02, 2020 7:11 pm
The ones I ordered from them are. Also read the description...
"H&R 1655572 Wheel Spacers are the answer if you need more brake clearance or just want a more aggressive look from your wheels. H&R spacers are hubcentric for a perfect fit and no vibration. H&R DR series spacers fit between the wheel and hub, using longer wheel bolts (sold separately)."
DavidRS4
Post by DavidRS4 » Thu Apr 02, 2020 7:38 pm
I just looked at the picture.
maars
Post by maars » Sun Apr 12, 2020 8:32 pm
There's this version too:
H&R B1655571 DR-System Wheel Spacer Set 16mm per axle Pattern 5x112-Hub 57,1mm-Bolt Size M14x1,5-Audi/Seat/Volkswagen/Ford-Black
Anyone know the difference between x571 and x572?
Have you tried EuroCarParts?
Otherwise Virdee on here can supply them.
Brooner
Post by Brooner » Mon Apr 13, 2020 6:22 am
I would go with a main supplier as above
As you will need longer bolts too
I would be weary getting those from ebay
Users browsing this forum: Google [Bot], Google Adsense [Bot], vailpilgrim, Zyox and 300 guests
