Help!! Cold start idle problem
GhiniRS4
Post by GhiniRS4 » Mon Mar 16, 2020 5:00 am
Hello everyone
Does anyone have a cold start idle problem?
My car the video
https://youtu.be/lzcg7vH49wI
A few minutes later the idle will be okay or the second start is okay too. Above, I feel losing the cold start program.
Please help!!
Thank you
Quango86
Re: Help!! Cold start idle problem
Post by Quango86 » Mon Mar 16, 2020 11:22 am
Hello everyone
My car the video
Please help!!
I would be checking the maf or idle control valve. Best to get a scan done and check what readings your getting.
Thank you
B7 saloon, koni Shocks and h and r springs, h and r spacers 8mm f+r, milltek non res with valves, milltek d/ps, k and n filter, full mrc carbon clean, mrc stage 2 with l/c and f/s 456bhp 522nm.
GhiniRS4
Post by GhiniRS4 » Tue Mar 17, 2020 7:06 am
Hello everyone
My car the video
Please help!!
Thank you
Thank you for your reply
So I spend a week on the test. Every time the test I need to wait for a car cold down. Finally, the problem solved today!
I check the MAF, ECU, Test vacuum leak (use the Smoke machine)... The problem is the solenoid valve. The problem not easy to find it, because it isn't obvious in the Smoke machine test.
Thank you, everyone. I thought I can not find it, until yesterday I ask on here.
I hope this problem can help need friends.
Thank
Quango86
Post by Quango86 » Tue Mar 17, 2020 9:51 am
Hello everyone
My car the video
Please help!!
Thank you
Thank
Glad you found it!
mikep99
Post by mikep99 » Tue Mar 17, 2020 10:20 am
Good to know - thanks :)
Mike
Users browsing this forum: Google Adsense [Bot], MTBear and 313 guests
