adsgreen
Post
by adsgreen » Fri Sep 28, 2012 11:21 am
Bleugh... thats what I'm going to be left with! Hmm - new centre console I think!
(anybody got prices and part numbers to hand?)
nij
Post
by nij » Thu Oct 04, 2012 4:16 pm
adsgreen wrote:It arrive this morning and it's pretty much what you'd expect.
Pretty well made and no obvious flaws - just working out cable routing.
Iphone sits in it fine and is stable - time will tell though if it can keep hold of it when having a bit of "fun".
Have tested the connection and it works perfectly - just plugs into the iphone cradle socket and voila. Power and signal boost.
So in principle a dead easy fit - just need to work out how the cradle fits in and how to access everything. Rather not pull the RNS-E out if I can get away with it!
Did you manage to install it?
Does this dock replace the cradle or does it connect to the Aux In? Can you do a write up about the installation and function of the dock?
Phantom Black R8 V10 plus, Capristo Exhaust
Phantom Black (B7) RS4 Saloon, MRC Stage 2
Mercedes E-Coupe 350CDi
stu
- 5th Gear
Post
by stu » Fri Oct 05, 2012 2:26 pm
adsgreen wrote:[image]
That's a lot of wires just for power! Any idea what the others do? Are they for different voltage outputs for different phones maybe?
This (and the part number for the console) is going to be very useful.
edit: ahh... that's not your car's console in the pic.
adsgreen
Post
by adsgreen » Fri Oct 05, 2012 3:57 pm
Not installed yet - to wet to do anything with the cars (and been uncharacteristically busy).
However the new dock is effectively an ipod extension cable. Anywhere your iphone/ipod connects then this will connect also.
Note: It's purely for the phone so don't go thinking you'll be able to play music and the like. You still need the cradle and adapter (but you are free to hide it whereever) and this dock connects to that.
Apart from that it's dead easy - it just replaces the ashtray.
nij
Post
by nij » Fri Oct 05, 2012 8:06 pm
adsgreen wrote:However the new dock is effectively an ipod extension cable. Anywhere your iphone/ipod connects then this will connect also.
I'm slightly confused, does this dock connects to the plugs where the cradle connects, in effect replacing the cradle and not an ipod extension cable for the ipod interface.
adsgreen
Post
by adsgreen » Sat Oct 06, 2012 1:25 pm
It's exactly what I said - the dock is just an iPod extension cable.
http://db.tt/rwSsfgZS
One end is a male iPod/iPhone connected like any other dock and the cable has a female iPod connector just like any iPod device (bar iPhone 5)
You either need to plug it into the cradle like the photo which means you can hide the cradle anywhere behind the dash OR plug into an existing iPod adapter located in the glovebox
PetrolDave
Post
by PetrolDave » Sat Oct 06, 2012 6:06 pm
adsgreen wrote:just like any iPod device (bar iPhone 5)
I just read today that the iPhone 5 needs different connectors and docking adapters to previous iPhones - surely that's not a good move by Apple?
adsgreen
Post
by adsgreen » Sat Oct 06, 2012 9:03 pm
Not really apples fault entirely...
Eu bringing in rules to standardise chargers.
Also the old one is massive taking up valuable space away from other components.
But charging 25 qud for an adapter is taking the piss
Tanna
Post
by Tanna » Sun Mar 08, 2020 11:32 am
What was the fix I have just fitted mk2 RNSE and getting no response from controller 56 & 37 so can't code it. Any ideas on how I can fix.
Vagcom test shows k1, k2 and can ok.
Nige_RS4
Post
by Nige_RS4 » Sun Mar 08, 2020 3:31 pm
Why don't you trying connecting your old head unit, change the values in
VCDS as needed, then re-connect the new one?
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
Tanna
Post
by Tanna » Sun Mar 08, 2020 5:38 pm
Nige_RS4 wrote: ↑Sun Mar 08, 2020 3:31 pm
Tried that but didn't work. I have disconnected and disposed off the original tv tuner to upgrade to digital maybe the tv tuner module not being present is causing this issue? I'll have to wait until new one arrives and plug it in.
Tanna
Post
by Tanna » Mon Mar 16, 2020 7:49 pm
Okay so analogue tv tuner swapped for hybrid tv tuner but can't see digital tv how do I get this to work?
Also whats the correct coding for rnse when I check fault codes on navigation it says incorrectly coded module. I have CD changer, tv tuner.
Users browsing this forum: Google Adsense [Bot] and 102 guests
