B7 rs4 whirring/buzzing/whirring noise
Oldmanmush
Post by Oldmanmush » Tue Dec 24, 2019 3:12 pm
Hi everyone I'm new to the b7 rs4 and must say I love it..........but I have a annoying problem with it
When the max revs 7000rpm message on the clocks changes to 60° oil temp I get an annoying whirring/buzzing/whirring noise appear around the gearbox area at first I thought power steering pump but it does not change with the engine speed i also did a power steering flush but i don't think it's the pump
Any ideas lads
Oldmanmush
Re: B7 rs4 whirring/buzzing/whirring noise
Post by Oldmanmush » Thu Dec 26, 2019 11:14 pm
Anybody??
12th
Post by 12th » Fri Dec 27, 2019 11:16 am
Does yours change at 60 degrees? Mine is 70.
Not able to help regarding the noise, I'm afraid.
Oldmanmush
Post by Oldmanmush » Fri Dec 27, 2019 12:05 pm
Yes it's pretty much when it changes to oil temp car quiet until this
It has to be some sort of valve opening or an auxiliary pump I'm new to the 4.2 so unsure how it operates
rwilsonrs4
Post by rwilsonrs4 » Fri Dec 27, 2019 9:52 pm
ive had no issue with mine atall in 9 yrs of use in my RS4 , so have a look at the front of the radiator .it might have some newer oil cooler fitted to the crash bar or something as the original ones can leak with the connectors corroded a bit ,so fancy ones will be maybe cheaper than the OEM , cant remember the type replaced but some folk have mentioned the buzzing drone through the chassis as the oem ones are mounted differntly so maybe the oil thermostat probably opens at that temp and then buzzing noise with the oil through the cooler
1/4 mile 12.01 secs 123.5mph
Oldmanmush
Post by Oldmanmush » Fri Dec 27, 2019 11:01 pm
Thanks is it a bumper off job
mikep99
Post by mikep99 » Fri Dec 27, 2019 11:12 pm
It's the Forge oil cooler that makes a quiet buzzing sound. Although it doesn't start buzzing at any specific temperature, or I haven't noticed it anyway.
You'll be able to tell of you've got a standard or Forge cooler by looking through the bumper mesh.
The OE cooler is mounted down below the radiator behind the power steering cooler.
The Forge one is mounted on top of the crash bar.
Edit - link to photo of the Forge cooler fitted: https://images.app.goo.gl/dbMX7uW262AESNdm8
Mike
Sent from my PRA-LX1 using Tapatalk
Oldmanmush
Post by Oldmanmush » Fri Dec 27, 2019 11:38 pm
Oh ok mine starts buzzing/whirring after its warmed up and can be intermittent almost like a power steering pump whine but it doesn't change with engine speed cars perfectly quiet until this kicks in
It sounds like the pedal box area (rhd) and by gearbox its doing my nut in I hate noises
YellowMessage
Post by YellowMessage » Mon Jan 27, 2020 6:27 pm
This is not much help to Oldmanmush but here is my experience. I noticed a whine after my Forge cooler was fitted - volume/frequency varies with engine speed though. Most days I don't hear it but on the odd day it is loud - around 2000rpm - it is the loudest noise the car makes (standard exhaust).
:greyrs4:
B16 Coilovers, Forge oil cooler - otherwise standard.
Toady1
Post by Toady1 » Mon Jan 27, 2020 9:17 pm
It could be the oil separator
DavidRS4
Post by DavidRS4 » Mon Jan 27, 2020 10:55 pm
No noise from my Forge kit.
Oldmanmush
Post by Oldmanmush » Tue Feb 04, 2020 10:16 pm
I don't think it has the forge cooler it still looks stock I can see it's at the bottom of the bumper
Oldmanmush
Post by Oldmanmush » Tue Feb 04, 2020 10:18 pm
Toady1 where is the oil separator located as I say it doesn't start buzzing until the max 7000 rpm message switches over to oil temp its almost as if a valve has opened and that's what's buzzing
Oldmanmush
Post by Oldmanmush » Thu Feb 27, 2020 5:32 am
Hi guys I've sorted my buzzing/whirring noise
The cars had a full service plugs filters oils engine/gearbox/diff coilovers the oil filter was quite bad (I've not long owned it) but I also removed the front bumper to check the oil cooler and to my surprise its had a new one along with new pipes but they were touching the body probably resonating through the chassis sorted them out and now it's like new no noises runs perfect
Halokimm
Post by Halokimm » Sat Apr 01, 2023 5:06 am
Hi oldmanmush, I have the same issue with the buzzing/whining noise after fitting the Forge oil cooler. Curious to hear what exactly you did to resolve this, how did you route the lines under the car where they go through the chassis "hole" just before they connect to the oil sump? Did you get rid of the hard hose clamp that comes with the forge kit, that is used to guide the hoses through the hole? Were the hoses touching the body or anything else anywhere else on your car that you fixed? Would really appreciate the help on this as it is really annoying of a noise. Thanks!
Users browsing this forum: Google Adsense [Bot], Tomrobc and 107 guests
