Im running 63cm front and rear with OEM 19s, no spacers but 275s. I got some slight rubbing on the little arch liner screw on big compressions but that’s it - removing the screw fixed it. Since had front wings rolled and it’s perfect.
How low is too low???
- 1st Gear
Re: How low is too low???
thanks, mine isn't that low, mines set at around 64cm rear with arch to top of rim at 60mm ant the front at about 65cm with arch to top of rim 75mm, I have a lot of B roads where I live and would hate to rip the wing to bits on some big bumps.jordanbutters wrote: ↑Mon Jul 08, 2019 11:10 pmIm running 63cm front and rear with OEM 19s, no spacers but 275s. I got some slight rubbing on the little arch liner screw on big compressions but that’s it - removing the screw fixed it. Since had front wings rolled and it’s perfect.
You got everything back together then? How does it ride with the 034 subframe bushes? Curious as I will be doing my subframes in the near future.James1984 wrote: ↑Tue Jul 09, 2019 11:45 amthanks, mine isn't that low, mines set at around 64cm rear with arch to top of rim at 60mm ant the front at about 65cm with arch to top of rim 75mm, I have a lot of B roads where I live and would hate to rip the wing to bits on some big bumps.jordanbutters wrote: ↑Mon Jul 08, 2019 11:10 pmIm running 63cm front and rear with OEM 19s, no spacers but 275s. I got some slight rubbing on the little arch liner screw on big compressions but that’s it - removing the screw fixed it. Since had front wings rolled and it’s perfect.
And most of all, pictures please!
Misano Red RS4 B7 Avant
coffey555 wrote: ↑Tue Jul 09, 2019 12:13 pmYou got everything back together then? How does it ride with the 034 subframe bushes? Curious as I will be doing my subframes in the near future.James1984 wrote: ↑Tue Jul 09, 2019 11:45 amStill a few jobs to do but it’s not on the road yetjordanbutters wrote: ↑Mon Jul 08, 2019 11:10 pm
Sorry missed your question, yes but not with spacers and had no rubbing.
Thanks, rear should be ok on mine but I may have to remove my spacers to avoid the front arch, 20’s are tempting though.
