New to me B7 - Clutch Problem
Wilko868
Post by Wilko868 » Wed Apr 03, 2019 3:22 am
Hi guys! First post here after picking up my first V8 a couple of weeks! A lovely B7 Avant in Misano!
This morning though when starting the car, I have found the clutch not fully actuating and not disconnecting the drive when fully depressed. It is actuating enough to allow the clutch to slip slightly but not enough to make gear changes possible without forcing it with a bit of the old Rev matching. There’s been no and is still no sticking of the pedal to the floor or anywhere in the throw like I’ve read in other threads.
Don’t know what would cause this to happen with the car stood? It was absolutely fine prior and there has been no obvious deterioration. The bite point has always been relatively low down in the throw so I can’t imagine it’s wear? There is still full correct feeling in the pedal and it does not ‘pump up’ - does anyone have any experience of this one?
Cheers!
12th
Re: New to me B7 - Clutch Problem
Post by 12th » Wed Apr 03, 2019 8:26 am
Has the bite point changed? A low one on mine meant wear and was remedied by a new clutch, I'm afraid.
When the pedal sticks down after hard use, that's remedied by Dot 5.1 clutch fluid (higher boiling point).
Sprint Blue B7 RS4 Saloon with MRC tweakery.
Covkiller
Post by Covkiller » Wed Apr 03, 2019 11:41 am
You will get lots of opinions, but you need a new clutch and flywheel.
akoblivius
Post by akoblivius » Wed Apr 03, 2019 7:57 pm
Buy mine. I really have a very well oem flywheel and clutch combo for bargain.
wimpievanzyl
Post by wimpievanzyl » Fri Apr 05, 2019 11:39 am
Agree with Covkiller invest in a new clutch and flywheel and all your issues will be solved.
ArthurPE
Post by ArthurPE » Sat Apr 06, 2019 6:38 pm
How many miles on the car?
I would do these steps to see if any correct the issue.
1 flush and bleed clutch fluid
2 check master and slave for leaks
3 replace slave
4 replace clutch last resort
Wilko868
Post by Wilko868 » Mon Apr 08, 2019 8:52 pm
How much is a flywheel? (Parts cost only) Cant seem to find it online?
Quango86
Post by Quango86 » Mon Apr 08, 2019 10:40 pm
Just purchased one from Rock auto in the states delivered to the door for around 480 that's the cheapest you will get.
B7 saloon, koni Shocks and h and r springs, h and r spacers 8mm f+r, milltek non res with valves, milltek d/ps, k and n filter, full mrc carbon clean, mrc stage 2 with l/c and f/s 456bhp 522nm.
ArthurPE
Post by ArthurPE » Tue Apr 09, 2019 2:40 am
You can do some research here
https://www.autohausaz.com/catalog/k/au ... _/flywheel
Looks like clutch + flywheel $950
Replace slave cyl, Fork and bolts while in there
Clutch comes with throw out bearing and pilot bearing
When I sold mine it had 85k miles and clutch was fine
Users browsing this forum: Bing [Bot] and 63 guests
