Ideal tyre pressure
Ideal tyre pressure
I've been running mine at 32psi front and rear which feels good but the orange tyre pressure light is constantly on
What is the lowest pressure I can get away with that won't trigger the orange light?
I thought there was something wrong with it as 32 is ok in my book, but the garage set them to 39 front and 36 rear which is way too harsh a ride IMO
With my black B7
I'm in B7th heaven
And with DRC
My ride is heavenly
I'm in B7th heaven
And with DRC
My ride is heavenly
Re: Ideal tyre pressure
I'm sure the spec is 38psi front & 35psi rear for 255/35/19's. The chart is in the drivers door sill, not sure what the lowest setting is right enough?
I would've thought if you run tyre pressures lower than manufacturer spec you'd get uneven tyre wear?
I run 36 all round and don’t get warnings.
I run mine At 36 psi all round as well, very even tyre wear and have dcc so cant say they affect the ride.
^^^THIS^^^
R8 V10 Gen 1 • Phantom Black • Coupe • Gated Manual • Quicksilver Valveless Exhaust • REP RamAir Filters • CF Interior/Engine/Side Blades • Wireless Apple CarPlay
RS4 B7 • Phantom Black • Centre Resonator Delete • Wireless Apple CarPlay
SQ5 TDI • Ibis White • Fully Optioned • Wireless Apple CarPlay
I use the manufacturer's recommendations on all of my previous RS4's and don't believe i got uneven wear certainly don't get uneven wear in my currant B8 and i have had that for 6 years
But i do rotate the tryes when changing from summers to winters
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
Ignore my post, I have a golf r, but follow the rs4 forums as well (it’s the dream) posted in wrong section, my bad.
I run standard with a PSI or so dropped off the fronts.
Sprint Blue B7 RS4 Saloon with MRC tweakery.
You can get away with a lot, b/c, IIRC, you can modify the warning thresholds of the TPMS, e.g. using VCDS, or the in-car setup.
Ignoring the manufacturer's recommendations towards lower pressure is, I would claim, at your own peril though.
You can set the pressures your happy with them store them in the menu and then you won't get the warnings coming on.
rs4 b7 daytona avant. Miltek resonated valved, Mrc stage 2
vw touran 2.0tdi, blue /black leather. family wagon!!.
repsol honda fireblade.
Zx12r b1 in black and gold. The colour to have!!
Wear is almost irrelevant. Note that too low a pressure is a major cause of blow outs. The tyres compress and flex too much in use and get too hot and burst. People incorrectly think too high a pressure is the problem.
Tyre pressure is not just some arbitrary thing one should choose. It’s set by the oem for a reason and they even go to the lengths of setting it according to load level of the car.
The Sticker on the car is what one should follow. There’s even an 18 inch spec if you want more comfort and willing to change wheel size for it.
I run 40psi front/back with 275/30/19, and good wear.
Users browsing this forum: No registered users and 92 guests
