How low is too low???
rwilsonrs4
Re: How low is too low???
Post by rwilsonrs4 » Fri Nov 16, 2018 8:23 pm
good you replied , i forgot to mention there was adjusment on the rears as they have the cambolt setup , which the front should have i suppose too but totally different upright , as they are manufactured to factory spec its all in normal specs with normal height settings even with suspension movement its in spec but for about a miniscule time there is no wear , but with suspension lowered a lot there is wear on inside over time as you also know , so adjustable top links would be good but are expensive but are better , good you got it set decent at first , same as i did although mine is only down 10mm so adjusted it by 1mm to even up toe in. all things in the green :thumbs:
1/4 mile 12.01 secs 123.5mph
James1984
Post by James1984 » Fri Nov 16, 2018 9:46 pm
Has anyone ever elongated the holes that the top mounts sit it to correct the front camber?
rwilsonrs4
Post by rwilsonrs4 » Fri Nov 16, 2018 9:54 pm
you cant do that as the load on the slots will move it back in , unless you weld washers or do a cambolt setup with welded thngs on it ,to remove it all and do the mods would be a lot more work than just fitting adjustable arms wjich are made by several companies if you afford it
FaisalJ
Post by FaisalJ » Fri Nov 16, 2018 11:07 pm
rwilsonrs4 wrote:good you replied , i forgot to mention there was adjusment on the rears as they have the cambolt setup , which the front should have i suppose too but totally different upright , as they are manufactured to factory spec its all in normal specs with normal height settings even with suspension movement its in spec but for about a miniscule time there is no wear , but with suspension lowered a lot there is wear on inside over time as you also know , so adjustable top links would be good but are expensive but are better , good you got it set decent at first , same as i did although mine is only down 10mm so adjusted it by 1mm to even up toe in. all things in the green :thumbs:
That’s a long sentence
2007 RS4 B7 Avant
Covkiller
Post by Covkiller » Thu Nov 22, 2018 3:55 pm
Jon_J don't roll, I tried this and my paint cracked, it pulled my wings out of shape, a nightmare. I have 20's and I am low low with adjustable top arms, corner weighted and setup etc.
I had my front wings lips flattened back at my body Shop i.e. heated tapped near flat other than to let the liner still slip in.
I have driven my car for years and been to the ring many times with no rubbing at all.
I will post my heights in the next couple of days as I'm away with work at the mo.
An old photo but my favorite and skiing fully loaded with wife and kids and still no rubbing:
Jon_J
Post by Jon_J » Thu Nov 22, 2018 8:10 pm
Covkiller wrote:Jon_J don't roll, I tried this and my paint cracked, it pulled my wings out of shape, a nightmare. I have 20's and I am low low with adjustable top arms, corner weighted and setup etc.
Thanks, he rolled one side with no issue at all, the other side when the wing had been pulled out, when he rolled it back the aluminium split. New wing time for me.
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
- Full Stereo install
S5 8T Cab White
A5 Cab 3.0 TDI Phantom Black
TrevoRS4
Post by TrevoRS4 » Thu Nov 22, 2018 8:35 pm
Tapped? Like with a hammer? I’m not sure how this could be better than rolling as you’re still deforming the metal by the same amount. Maybe the heat was the key.
JonJ, was the one with the fatigue crack heated?
Jon_J
Post by Jon_J » Thu Nov 22, 2018 8:45 pm
Yes both sides heated. The problem with aluminium is if you bend it one way and then back again it breaks. Simple lol
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
TrevoRS4
Post by TrevoRS4 » Thu Nov 22, 2018 8:49 pm
Mine didn’t break but I only pushed it back to the factory position, no extra roll. As mentioned though it has a little ripple look to it that I need to try PDR before going the new wing route.
Jon_J
Post by Jon_J » Thu Nov 22, 2018 9:42 pm
TrevoRS4 wrote:
TrevoRS4 wrote: Tapped? Like with a hammer? I’m not sure how this could be better than rolling as you’re still deforming the metal by the same amount. Maybe the heat was the key.
Use Dragon Dents, I’ve never seen anyone as good as them.
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
Covkiller
Post by Covkiller » Thu Dec 06, 2018 4:22 pm
Jon_J my heights from ground to top of arch :thumbs:
Front 63cm
Rear 64cm
What are yours? :thumb:
James1984
Post by James1984 » Fri Dec 07, 2018 1:59 pm
Would you say the rear on this was a similar height to SS+?
Covkiller
Post by Covkiller » Fri Dec 07, 2018 6:10 pm
No as I had SS originally
sportsandclassic
Post by sportsandclassic » Thu Dec 13, 2018 7:07 pm
rwilsonrs4 wrote:you cant do that as the load on the slots will move it back in , unless you weld washers or do a cambolt setup with welded thngs on it ,to remove it all and do the mods would be a lot more work than just fitting adjustable arms wjich are made by several companies if you afford it
This is exactly how Porsche cars have their camber adjusted... ?
James1984
Post by James1984 » Wed Jul 03, 2019 11:22 pm
Don’t suppose you ever ran that height with 19’s and spacers did you, im setting the height on mine and I’m worried about the front rubbing
Users browsing this forum: Google Adsense [Bot] and 121 guests
