Fitting coil overs
AlexB7RS4
Fitting coil overs
Post by AlexB7RS4 » Sun Jun 03, 2018 2:39 pm
Standard story - knock knock DRC is gone.
I’m just about to buy in some new coil overs, still tossing up between B14s, B16s and KW V3s. Really looking for the best ride quality over out and out performance. I don’t track the car but I do hills runs from time to time and do give it a good squirt. It’s a daily for me that I also occasionally do long trips in, so having some compliance and behaving on Adelaide’s relatively average roads is important.
Anyway, what else should be done at the same time? ARBs I hear are a must, and I’m getting uneven tyre wear so planning to put adjustable front UCAs on to counter the camber. Anything else I should look at doing while the suspension is out? Bushing kits etc?
Car is a 2007 Avant, 120k km on it, has been well looked after and other than the suspension knock feels nice and tight.
Rw@@dy
Re: Fitting coil overs
Post by Rw@@dy » Sun Jun 03, 2018 5:35 pm
B14s on mine, I much prefer the ride. I moved from drc with standard wheels/tyres to b14s with 20s and 30 profile tyres as well. If you’ve got ss+ already then probably don’t need to update the arb, if not then most just suggest changing the rear arb only
FaisalJ
Post by FaisalJ » Mon Jun 04, 2018 8:27 am
I would have no issues daily driving mine (KW v3 set soft, with H&R ARBs) - the ride is plenty supple enough.
I’ve briefly been in a car on B14s and the ride felt just as comfortable.
2007 RS4 B7 Avant
AlexB7RS4
Post by AlexB7RS4 » Mon Jun 04, 2018 12:58 pm
Thanks guys,
When you did your coil overs, what else did you do? I.e any bolt / bushing kits that should be done at the same time?
Rw@@dy
Post by Rw@@dy » Mon Jun 04, 2018 3:10 pm
I didn’t do anything, just had coil overs fitted then alignment done
rs user
Post by rs user » Mon Jun 04, 2018 4:09 pm
i wouldnt fit the adjustable front arms unless you are using on track-once the front subframe is central and camber even/toe adjusted it will be fine for tyre wear
mikep99
Post by mikep99 » Mon Jun 04, 2018 4:16 pm
When I had mine done I renewed all the arms. One of the bushes had an advisory on the previous mot so thought get it all done at once.
Bit less on labour and tracking etc overall.
Mike
Sent from my Nexus 5 using Tapatalk
AlexB7RS4
Post by AlexB7RS4 » Tue Jun 05, 2018 3:18 am
Arthur - I have the KW HAS at the moment and I’m getting excessive wear on the inside front tyres with it lowered. Looking to even that out.
Thanks for the responses so far.
mikep99
Post by mikep99 » Tue Jun 05, 2018 6:02 am
If you're running that low, you'll need adjustable arms.
Is it 034 who do them?
I think Me Fish had them on his. ?!?
Sent from my Nexus 7 using Tapatalk
rs user
Post by rs user » Tue Jun 05, 2018 10:13 am
its the toe that wears tyres-negative camber up to -3 deg or so wont cause excessive wear,dont think you would be anywhere near -3 deg camber on a lowered rs4,mine on b14[ableit set at at max permissable height] is about -1 deg appx,if your camber is uneven on front[ie excessive on one side] you need to move the subframe across a bit
nice looking rs4 in first pic too... :bowdown:
AlexB7RS4
Post by AlexB7RS4 » Tue Jun 05, 2018 1:28 pm
Thanks. The front is dropped a bit from the pic above, the tyre gap matches the rear. It’s not excessive but enough to give the car pretty much the perfect stance.
I’ll look at the camber arms anyway I think. I have heard the arms are a wear item. Should I do lowers at the same time?
rs user
Post by rs user » Tue Jun 05, 2018 7:31 pm
like a lot of folk i did the front arms upper/lower and droplinks when it was apart
here in the uk we suffer terribly with the front pinch bolts seizing[the ones that hold the upper arm outer knuckles to the suspension upright]-adds to the job,in a friendlier climate they may come out a little easier-but watch out for this bit causing you grief in any case
marc1
Post by marc1 » Tue Jun 05, 2018 10:08 pm
I’ve heard it’s better to go for Stern over 034.
AlexB7RS4
Fitting coil overs
Post by AlexB7RS4 » Fri Jun 08, 2018 3:29 am
KW V3s ordered with H&R ARBs. Thanks all for the input. Looking forward to getting rid of that nasty knock! Hoping I feel the difference with the ARBs too - be nice if she becomes a little more playful
junior123
Post by junior123 » Mon Jun 11, 2018 4:58 pm
You’ll have to let us know how you get on. Based on a fair amount of research I’m still deciding between kw1’s (play it safe all rounder?, kw3’s (although I don’t think i’ll need to adjust) and billstein b14’s (“the drivers choice” according to those I’ve spoken to).
Users browsing this forum: Google [Bot] and 91 guests
