Cruise control fault RS4 B7
DavidRS4
Re: Cruise control fault RS4 B7
Post by DavidRS4 » Mon Feb 12, 2018 7:27 pm
Clutch switch solved my non working cruise control. All good now.
Kenny147
Post by Kenny147 » Mon Feb 12, 2018 11:15 pm
I just had this exact problem, so I’ve had the joy that is reading countless threads on it. My upper clutch switch (black/white casing) failed and I couldn’t get the cruise control to engage. This is the switch that disengages the CC if the clutch pedal is depressed.
The lower switch has a blue casing and allows the car to start without depressing the clutch. Apparently, it’s also the switch that causes the revs problems, when changing gear. (Didn’t have this problem, so I can’t be sure)
Here are the part numbers
Upper Clutch Switch (Black/white casing) 7H0927189
Lower Clutch Switch (Blue casing) 6Q0927189
They’re pretty cheap, so it might be worth changing both and be done with it. The upper one is dead easy to change, although there’s an order to changing the lower one and where the clutch pedal is when you put the new one in. Worth getting a pdf of the Audi manual before hand as it seems plenty of people have broken new switches, when replacing the lower one.
HPsauce
Post by HPsauce » Mon Feb 12, 2018 11:20 pm
Surely the operation of these switches can be tested with VCDS to confirm they are the problem?
TonyHayers
Post by TonyHayers » Tue Feb 13, 2018 3:09 pm
Nope. But the symptoms are always the same, so easy to diagnose.
06 Phantom Black Saloon:
^ GONE :cry:
PaulH13
Post by PaulH13 » Tue Feb 13, 2018 7:44 pm
Does anyone have any links to these as i am getting confused it says one in wht/blk but i get them showing as blue also ?
and the blue one comes up in searches as other part numbers and i would just like to get the correct items
Thanks in advance
Post by MikeFish » Tue Feb 13, 2018 9:10 pm
Thanks in advance
I think they updated the part a few years ago and the part changed colour.
Post by MikeFish » Tue Feb 13, 2018 9:12 pm
They are easy to change and about £18 each to buy. I just changed mine as a sensible precautionary measure even though it wan't failing.
Kenny147
Post by Kenny147 » Wed Feb 14, 2018 3:49 pm
Thanks in advance
Paul,
The part numbers and casing colors I’ve mentioned in my post above are the latest numbers. The original parts were updated with new part numbers in the last couple of years. The same reason you’re getting confused, is why I ended up reading endless threads. So, I can guarantee they are the latest part numbers.
It’s not a UK/EU website but here are links that show the parts and also the previous revisions for each part.
https://www.ecstuning.com/b-genuine-vol ... 7h0927189/
https://www.ecstuning.com/b-genuine-vol ... 6q0927189/
RichieB
Post by RichieB » Wed Feb 14, 2018 4:16 pm
I also changed this upper clutch switch out last year due to no cruise control / holding down of starter button and used part no. 7H00927189. Bought from a local stealer and the casing was black/white £22.
This was the helpful link viewtopic.php?f=35&t=114660#p731104 I used to install as I didn't want to be breaking it after reading the plunger mechanism can be easily damaged if not installed in a certain way.
PaulH13
Post by PaulH13 » Tue Feb 20, 2018 8:04 pm
Thank everyone parts ordered and on the way :thumbs:
Kenny147
Post by Kenny147 » Tue Feb 20, 2018 8:37 pm
You'll need these then, if you haven't already found them.
And
RS4Guy
Post by RS4Guy » Tue Mar 26, 2019 7:22 pm
This is getting confusing. I ordered a clutch switch from Audi which according to their diagram is part number 927 189. However, this is not the clutch switch, it’s the brake switch. The diagram shows this switch as being on the left but when operating the pedals this switch is moved by the brake pedal, not the clutch. The same error appears to occur in this guide. Am I going mad?
From Audi
Current: 2007 B7 RS4 Avant sprint blue
Current: 2004/04 TT V6 DSG dolomite with BBS LM.
Gone list: 2018 C7 RS6 Performance in Nardo, 2007 B7 RS4 Avant Phantom Black (should never have sold it), 2003/03 8N TT 225 Black, 2002 8L S3 in Silver, Morgan Aero, Renaultsport Clio, Polo Gti...
ArthurPE
Post by ArthurPE » Sat Apr 06, 2019 6:46 pm
PaulH13 wrote:
Mon Feb 12, 2018 7:21 pm
is this a easy fix to diy not at all mechanically minded unless its the old ford pinto engine lol
Simple but awkward
Take a look at it first
Remove trim panel for access
Not sure that any tools are even required
Unplug connector from switch
Release switch from bracket by depressing tabs
Snap in new switch
Plug connector in
dhali
Post by dhali » Sat Apr 06, 2019 9:59 pm
Simple but awkward
Snap in new switch
Plug connector in
In the guide posted above it says to pull the plunger out first before installing . Is this not necessary then ?
ArthurPE
Post by ArthurPE » Sat Apr 06, 2019 10:46 pm
Simple but awkward
Snap in new switch
Plug connector in
Iirc it is shipped depressed
You twist it and it pops out
Been several years
Users browsing this forum: Google [Bot], highrise and 90 guests
