Gearbox oil
Turbo_scotty
Gearbox oil
Post by Turbo_scotty » Mon Dec 04, 2017 6:03 pm
:bash: :bash:
Right I’ve used the search and read a few bit on here and just managed to complely confuse myself 😂
Is redline mt-90 ok to use ?
MIDZ
Re: Gearbox oil
Post by MIDZ » Mon Dec 04, 2017 10:12 pm
Me personally, I would stick to the OEM oil(s) from Audi for gearbox/rear diff, it's about £110 for the two different types of oil & quantity's required, ok you can get less expensive all-in-one oil elsewhere but let's be honest you're probably only going to change it once.
Turbo_scotty
Re: Gearbox oil
Post by Turbo_scotty » Tue Dec 05, 2017 3:32 am
Tbh mate I was just goin to buy the genuine stuff . I just didn’t no if there was a alternative that was just as good / better
I’ll phone TPS tomorrow see what’s what 😉
Grandadg90
Re: Gearbox oil
Post by Grandadg90 » Tue Dec 05, 2017 9:00 pm
You will need gulf competition oil 75w/90, 3.2L for the gearbox and 0.9L for the diff.
Can buy from Opie. The oil will work in diff and gearbox.
Daytona Grey, Bilstein Coilovers, Pre-cat delete, Centre resonator delete, IM flaps/vains delete, Interior/Exterior LED kit, CAI, Black Optics.
Other car: Bread Van
ixi_ixi
Re: Gearbox oil
Post by ixi_ixi » Wed Dec 06, 2017 11:00 pm
I have recently changed the gearbox and diff oil too and I went with VW/Audi factory oil.
You may want to research a bit more on user feedback on other Audi forums for aftermarket gear box oil. I understand most people don't have issues using aftermarket gear box oil. However, I read a few negative comments (eg. poor shifting, more notchy feel etc) using aftermarket gearbox oil that meet factory specifications. I suspect for those negative user feedback, there might be other factors involve (e.g. gearbox condition and wear out synchro etc) and might not be just due to aftermarket gearbox oil itself.
BTW, I found that it would be MUCH cheaper to order the factory oil from VW dealer than Audi dealer. The part number is the same.
B7 RS4 Cabriolet
Ported and deflap manifold, carbon fibre intake, piggies, MRC remap and heaps of preventive maintenance works lol
Rodney007
Re: Gearbox oil
Post by Rodney007 » Fri Dec 08, 2017 6:29 am
2 weeks ago I just changed mine to Redline MT90 and noticed smoother shifting than the Audi recommended stuff which I had put in there recently too.
I also run it in another vehicle and noticed significantly better shifting.
Its very good, many will recommend it also and its spec matches our vehicles oil requirements.
