Tempermental fan
Tempermental fan
This is stating to drive me nuts... 5-10 mins after stopping the engine, the fan kick starts full blast... put the key in the ignition, it stops. Walk away another 5-10 mins, it starts again. Any ideas? Worst case scenario, I don't mind disconnecting it for the night. If anyone could tell me where the connector is and if it is easy access. Cheers chaps (and chapettes).
Mugello Blue 06 Plate, MRC stage 2 map, stage 2 manifold, pre-cat delete, CAF
Re: Tempermental fan
I Would say water temp sensor on the engine, think its at the back.
I had similar issues with fans it was water in the ecu box under the scuttle panel, it had destroyed a few relays but nice & cheap to replace & haven’t had any issues since.
RS4 B7
MRC stage2 436ps-487nm
Revolution intake, custom CAF, carbon clean, deflaped manifold, JHM manifold spacers, Forge oil cooler, Forge spacers, full de-cat, Scorpion cat back, Trup's LED's, 20' S5 wheels, KW V3's.
Launch control & flat shift
Thanks chaps. I'll look into what you've suggested.
Users browsing this forum: No registered users and 141 guests
