Comfort to buckets, s button bolster inflate?
Dannorton
Post by Dannorton » Tue Aug 29, 2017 10:14 am
Hi guys, I'm sure it's come up already but can't seem to find anything.
I'm going to be swapping my comforts to buckets this weekend. Has anyone come up with a way of coding the inflatable bolster to work with the s button?
And how do I code the airbag light out with VCDS if it comes on?
Thanks in advance!
coffey555
Re: Comfort to buckets, s button bolster inflate?
Post by coffey555 » Thu Aug 31, 2017 12:10 am
Hi,
I did the same thing with mine a few years ago. As far as I know there is no way to get the bolsters to inflate when you press the S button on the steering wheel on a car that has swapped from comforts to buckets. You can toggle it on and off in the DIS once you enable the coding but it still does nothing.
To be honest, I would have switched it off anyway, so all my S button does is change the throttle response as my exhaust valves are bypassed.
I got lucky, my car was already coded so I had no airbag warning lights when I changed the seats over. The bolts were not exactly tight either so I suspect the previous owner had removed the comfort seats at some stage as well.
Will see if I can find the coding changes for you.
Misano Red RS4 B7 Avant
Post by MikeFish » Thu Aug 31, 2017 12:21 am
I thought you plugged a resister into the loom to stop the air bag warning lights coming on.
coffey555
Post by coffey555 » Thu Aug 31, 2017 8:03 am
You do but on the later spec bucket seats it is already built into the yellow connector plug.
Dannorton
Post by Dannorton » Sat Sep 02, 2017 7:34 pm
Thanks for the info! The seat I'm buying have a yellow plug so fingers crossed the airbag shouldn't be an issue! I'm really wanting the bolsters to inflate with the sport button, so will have to do some more digging!
Dannorton
Post by Dannorton » Mon Sep 04, 2017 1:15 pm
Managed to get the seats in yesterday, no airbag issues! Really after the bolsters to inflate with the sport button if anyone can point me in the right direction? Cheers
Dannorton
Post by Dannorton » Mon Sep 04, 2017 2:23 pm
Could do with knowing how the s button sends a signal to the seat etc.. could maybe a wiring problem with cars that came with comfort? I noticed the wiring is different on the red plugs?
Jimbob71
Post by Jimbob71 » Mon Sep 04, 2017 8:28 pm
Hopefully this photo works Image
Sent from my SM-G900F using Tapatalk
Jimbob71
Post by Jimbob71 » Mon Sep 04, 2017 8:40 pm
Have a read through that I'm not great technically but there is a control unit for that might need reprogramming or might be a different control unit for comfort seats/buckets, hopefully you will get a sound answer from a tech guy on here!
hybridpaintworks
Post by hybridpaintworks » Sun Sep 17, 2017 11:15 pm
Check the the sport seat mode is activate mine wasn't
Post by Ian_C » Mon Sep 18, 2017 7:11 pm
Anyone got a reliable source for air bag resistors for the older seats? ie. Not the built-into-the-seat type. Need to pick up one to cancel a warning myself
iconic78
Post by iconic78 » Tue Sep 19, 2017 1:06 pm
Have you looked at the coding in the comfort module via VCDS?
Post by Ian_C » Tue Sep 19, 2017 1:47 pm
Mine is an old B5 jalopy tip-runner, the passenger seat is giving an error on VCDS, so I want/need to unplug it and plug in a resistor instead
mikep99
Post by mikep99 » Tue Sep 19, 2017 1:51 pm
Hi Ian,
If you fancy doing it yourself its easy enough...
The connector that plugs into the box on the car side is part number 8D0971974 which cost about £5 each from your dealer.
And the resistors I used are 4.7 ohm 0.25 watt which can be picked up for peanuts from ebay - http://www.ebay.co.uk/itm/Carbon-Film-R ... 1259792533.
Then a bit of heatshrink over the top of the connectors once the resistors are in place... and voila...
ta
Mike
EDIT - part number above is what I used in my B7
Post by Ian_C » Tue Sep 19, 2017 2:02 pm
LEGEND, thanks very much, I will have a look into this! :beerchug:
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 83 guests
