Coolant leak.
Coolant leak.
Looks like the Aux rads have give up the ghost. Coolant emptied completely, leak seems to be drivers side. I've been led to believe I can remove the aux and do away with them as they aren't required for the uk climate? Present weather excluded
RS4 B7 Sprint Blue, Miltek non res, Bilstein coilovers.
BMW 320d Le Man Blues M Sport LCI
205 GTI 1.9 Black non cat non power steering Completely standard.
Re: Coolant leak.
Just ditch the drivers side radiator and throw in a cold air feed. This what I've done and even with ~30c on Saturday the engine temp gauge did not go over 12 o'clock.
Re: Coolant leak.
I was thinking along those lines just wanted confirmation before going ahead.
Your rs is looking outstanding by the way.
Cheers.
Cheers.
Re: Coolant leak.
Have you seen this? - viewtopic.php?t=98322 It took a couple of hours from memory.
Re: Coolant leak.
This is what you need
Look at this on eBay http://www.ebay.co.uk/itm/300788471994
Look at this on eBay http://www.ebay.co.uk/itm/401346084965
