Howdy all
probably not many people with to much knowledge on this but today my battery light illuminated every 5 mins or so for about a second and went out... wasnt under hard throttle or anything.
i unloaded the alt so no lights or heaters etc and still did it, has anybody else experienced? could it be belt slip ? seems doubtful as the revs were not high or being driven hard , alt on way out? or maybe its a unknown feature of the supercharged cars haha..
Will talk with MRC this week i suppose
cheers
Ross
TTS charged RS4, intermittent battery light
TTS Charged RS4 plus all the goodies
- Dantheman84
- 1st Gear
Re: TTS charged RS4, intermittent battery light
Just sounds like alternator is on its way out to me if you have a multi meter see if it's charging over 13.5v (about) then load alternator up turn lights on etc see if stays above 13v
RS4 kw v3 full miltek no cats
Intake spacer deflap stage 2 flat shift launch
Kawasaki ZX10R 197bhp
What makes you think it's related to the charger?
nothing really only the belt that drives the charger i assume drives the altenator
I had similar on mine, flashed a few times.it then ate the belt whilst having a spirited drive which was scary.
Turned out the tensioner had a crack on the mounting point and was slipping, this then split and lost all tension , ate the belt into a million pieces .changed the lot and all good.
Take 2 mins to rule out, whip off the undertray and you can see if it may or may not be that.just a thought mate
RS4 B7 Saloon, Phantom Black , Billy B14 and ss+ arbs, LED's all inside & out with Dectane LED tailights. deflap, MRC Stage 2, Carbon Clean, no pre-cats, Custom Blueflame non res cat back exhaust, AP Racing Discs, alcantara wheel, gaiter and handbrake retrim, R8 gearknob, red belts (anyone want to swap belts for black ;-/ ) 438PS
To note id also noticed a little belt whine from cold,shortly before this started
Users browsing this forum: Google [Bot], highrise and 86 guests
