Bit of a thread resurrection lol. The rnse system is so dated think it may be easier just to upgrade the whole unit.FaisalJ wrote: ↑Fri Feb 19, 2016 3:29 pmYou will indeed need a fascia; I got mine from connects2. There are a couple of different versions available, the one I've got at the moment is on the link below:Ellis wrote:Quite fancy this for the RS now. Can always reinstate the RNS-E should I ever need to sell.
Tell me more; would I need a fascia plate for SPH model? Installation & wiring easy enough? I haven't fitted a head unit since around 2005
http://www.caraudiodirect.co.uk/connect ... di-a4-2002
I also had the installer spray it with a couple of coats of Tamiya model paint ("Black Rubber" TS-82 off ebay). It matches the RS4 dash colour and texture very well.
You'll also need a module to retain the steering wheel controls. I believe the installer also got this from connects2, but I'm not sure on the part no.
Can I ask did you need any wiring adapters for the unit to link it to the standard audi wiring?
I have the SatNav Plus and BT phone system. Will this head unit still work with the phone kit?
Any help or pointers appreciated
