Intermittent Water Leak
I have an intermittent water leak that appears to come out of the front bumper, in front of the front off side wheel.
Any suggestions as to where the water could be coming from?
Re: Intermittent Water Leak
Aux radiator,
One either side on the rs4. Commom thing.
Head light washers? Does it leak when you wash the screen with the lights on?
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
- Full Stereo install
S5 8T Cab White
A5 Cab 3.0 TDI Phantom Black
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
Thanks folks. It would be good if it was the headlight washers, however it's more than likely the aux radiator!
Intermittent? If it was aux rad why intermittent? Surely it would leak all the time?
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
Fun and games
My Aux rad only leaked when it fancied it, some days it wouldnt leak, other days it used a fair amount.
There is occasionally steam emits from that corner of the car when I join a traffic queue, so fairly conclusive that it's an aux rad.
Not a clue why it would be intermittent.
The aux rads are only used as an additional cooling when coolant reach a higher temperature, otherwise the thermostatic valve stay close, so no water will circulate the aux rads.
Phantom Black R8 V10 plus, Capristo Exhaust
Phantom Black (B7) RS4 Saloon, MRC Stage 2
Mercedes E-Coupe 350CDi
What is it that'll be leaking. Is it the radiator or a hose that is connected to the radiator?
If it's the radiator, has anybody had any success using a radiator sealant, rather than replacing the radiator?
If it's the off side then bin it fit a cold air feed...
My aux is working fine atm so I've not done it but its a very common mod. Just do a search mate.
Fun and games
My finished example instead of replacing with another aux rad
Users browsing this forum: No registered users and 172 guests
