Brake removal/ replacement tips.
jonytek
Post by jonytek » Thu Apr 27, 2017 3:16 pm
I'm thinking of doing a brake upgrade myself to try and save a few quid.
Can anyone tell me how easy it is to get the rear disks off and also if it's easy to unclip the handbrake cable. Last time I did the rear pads I couldn't figure out how to get the disks off. I'm sure it's easy but couldn't find anything online.
Also has anyone done a ceramic upgrade themselves, I assume it's a straight change for a set off an RS4? I've done disks, pads and lines before so I would think it would be more or less the same.
Any tips are appreciated.
Cheers.
BUILD THREAD
IG: @bad_rs_4
BenHol
Re: Brake removal/ replacement tips.
Post by BenHol » Thu Apr 27, 2017 3:23 pm
I think it just be easier not to fit the ceramics and sell them to me!!! Very jealous!!
RS4 B7 - Phantom Black, 20in RS6 C7 alloys, Joey mod, detango, led drl, black optics, Bilstein b16, Michelin ps4s, centre res delete, black tips, 8mm spacers, vx lenses, RS embossed xenon, Carbon splitter, 034 ARB.
nij
Post by nij » Thu Apr 27, 2017 7:08 pm
RS4 doesn't come with rear ceramic brakes option, but I can remember a couple of members on here did do the conversion with R8 steel and ceramic rear setup. You'll need a custom made bracket though.
You've just missed out by an hour and twenty minutes
Phantom Black R8 V10 plus, Capristo Exhaust
Phantom Black (B7) RS4 Saloon, MRC Stage 2
Mercedes E-Coupe 350CDi
daytonamart
Post by daytonamart » Thu Apr 27, 2017 7:34 pm
Surrey Sam is your man Jonytek, he has done the ceramic brake upgrade.
Don't remember him doing a "how to" on this but I'm sure he'd have some sage advice.
Gone B7 RS4 Sprint Blue Avant
Gone B7 A4 Reflex Silver
jonytek
Post by jonytek » Thu Apr 27, 2017 7:50 pm
I've got the bracket Nij. I just remember struggling to get the disks off the back. I'm just trying to gauge the difficulty as I need to try and save a few bob now hence the reason I'm thinking of doing it myself. Build is wayyyy over budget.
He'll be along soon I'm sure otherwise I'll hit him up. Cheers.
BUILD THREAD
IG: @bad_rs_4
rickster147
Post by rickster147 » Thu Apr 27, 2017 8:18 pm
Which part are you having trouble with with removing the rear discs? Undo the 2 slider pin bolts you can leave one in and just tilt it over remove the pads
Then the disc should cone out with the caliper frame still fitted
Rs4 b7 In avus silver with b14 Bilstein coilovers, centre resonator delete with x pipe and piggie cats gutted
Headlights detangoed trups led kit drl reverse and numberplate kit
Previous audi
rs6 c5 - mrc stage 2 remap-itg filters-forge dumpers-center decat with miltek kw coilovers- h and r
I call her the growler lol
jonytek
Post by jonytek » Thu Apr 27, 2017 8:25 pm
I can't remember exactly as it was a few months back but I took the caliper off then smashed that mother with a mallet but it didn't budge.
BUILD THREAD
IG: @bad_rs_4
gt2
Post by gt2 » Thu Apr 27, 2017 10:18 pm
Silly question but you took the retaining bolt out?!
jonytek
Post by jonytek » Fri Apr 28, 2017 7:22 am
Lol. Yeah I would have mate. I'm no f1 engineer but not that daft. I think I've managed to rope another member into helping me out so hopefully it'll be ok.
BUILD THREAD
IG: @bad_rs_4
gt2
Post by gt2 » Fri Apr 28, 2017 8:05 am
jonytek wrote:
jonytek wrote: I can't remember exactly as it was a few months back but I took the caliper off then smashed that mother with a mallet but it didn't budge.
Haha fair enough. I changed mine a few month back. Probably just need to get a bit more medieval with the hammer Image
Surrey Sam
Post by Surrey Sam » Fri Apr 28, 2017 9:48 am
You should now have the Ceramic coding in a PM :thumbs:
My tip for removing the rear discs, as they do require some hefty persuasion, is to wind a couple of the wheel bolts back in by a few threads. Then give the disc a good clout from the inside, rotate 90 degrees and give it another clout, keep going and eventually it will come adrift. It won't fall off because the wheel bolts are holding it from doing so. Remember that the rear pistons need to be wound back in with pressure, so make sure you have the correct tool for that, as a set of grips won't do it.
jonytek
Post by jonytek » Fri Apr 28, 2017 9:56 am
Thanks Sam I'll take a look now. Maybe I gave up too early last time as I assumed something was wrong and didn't want to damage the disks. I've for a piston rewind tool for the rear calipers from when I did the pads last time so should be fine. Thanks for your help.
BUILD THREAD
IG: @bad_rs_4
rickster147
Post by rickster147 » Fri Apr 28, 2017 12:42 pm
You can use long nose pliers to wind them in too if you don't have the correct tool
Previous audi
jonytek
Post by jonytek » Fri Apr 28, 2017 12:54 pm
Ill try and do a 'how too' as others might find this useful. I know there's been a lot of interest around the rear R8 setup too.
BUILD THREAD
IG: @bad_rs_4
Users browsing this forum: Google [Bot] and 279 guests
