Exterior car cover for the RS4.
RS04YOB
Re: Exterior car cover for the RS4.
Post by RS04YOB » Fri Mar 31, 2017 8:45 am
dougle_turbo wrote:
Thu Mar 30, 2017 7:36 am
RS04YOB wrote:
Wed Mar 29, 2017 11:16 pm
That is mine in the pic a lot of people say the are wank car covers I use the car as fun, every time I put the cover on the car is fully cleaned, I see it as damage limitation if the cover is on there are no cats pissing on the car and climbing on it. The car is kept in a car port over night which helps a bit to keep it clean, No moister has got trapped under this cover moister only get trapped when it is not exposed to air I did put a body Shop cover on also but that did trap moister resulting in fading effect which can be cured with Isopropyl alcohol in the day light sprayed onto the area.
No doubt the sheep shagger that ancestors where deported from the UK for stealing cheese 100 years ago will be commenting and will be on in a min and you will all be blowing smoke up his hoop and disregard any reply to the thread anyhow.
The cover was from http://www.carcovershop.co.uk/
Thanks RS04YOB, so you reckon the cover works well? Maybe it is worth a try, totally fed up with the amount of dust that seems to be attracted to the car. Do you get any unwanted attention/ people wanting to see whats under the cover etc?
You lost me on the second paragraph.
Frostie: how long were you keeping the car under a cover for?
The cover works better than not having one, having the local Tom cat pissing on and sitting on it when its pissing down, at the rear of the cover the boot area it is starting to degraded due light it has faded quite a bit, I just use a detailing spray over the car to spruce it up after wards. The car is most of the time blocked in by another one
Wotsirb
Post by Wotsirb » Wed Apr 05, 2017 12:54 am
I am using a Specialised covers StormShield +. Pictures in my for sale post.
viewtopic.php?f=63&t=124208
Toy: '07 B7 RS4 Avant Sprint Blue
Daily: 06 B7 2.0T Special Edition Avant
Previous: '09 B8 2.0T Quattro S line Avant
- OEM Defined - Instagram: @OEMDefined - Facebook: https://www.facebook.com/OemDefined/ -
Users browsing this forum: Bing [Bot] and 111 guests
