TPMS
MarksRS
TPMS
Post by MarksRS » Sat Sep 10, 2016 9:28 pm
I keep having the TPMS (Tyre Pressure Monitoring System) message appear on my display. I have reset countless times, but it keeps coming back. Does anyone know why this is happening (aside from the obvious of tyre pressures being down - which they're not) and how to fix?
Thanks.
pule333
Re: TPMS
Post by pule333 » Sun Sep 11, 2016 10:02 am
MarksRS wrote:I keep having the TPMS (Tyre Pressure Monitoring System) message appear on my display. I have reset countless times, but it keeps coming back. Does anyone know why this is happening (aside from the obvious of tyre pressures being down - which they're not) and how to fix?
Thanks.
Quick fix: disable with vagcom.
Long fix. Replace all sensors.
RS4 B7 aka Vinnie
Markwes
Re: TPMS
Post by Markwes » Sun Sep 11, 2016 11:06 am
Don't know if I got lucky but I just unplugged the TPMS antenna behind the rear bumper grille and plugged it back in and its worked perfect ever since. Its worth having the sensors checked at a local tyre fitters, I used National tyres and they checked them for free, it helped narrow the fault down to the antenna.
Audi RS6 c7 2014| Estoril Blue | Dynamic pack | Sports Exhaust.
MarksRS
Re: TPMS
Post by MarksRS » Sun Sep 11, 2016 5:35 pm
Thanks. Audi reset it via the trip computer (which is what I was doing anyway), but I'll try and unplug the antenna, however not being the most hands-on, can you advise exactly where this is? A picture would speak a thousand words!
Thanks.
Markwes
Re: TPMS
Post by Markwes » Sun Sep 11, 2016 6:24 pm
IMG_4053 (2) - Copy.JPG (37.77 KiB) Viewed 2653 times
Remove highlighted center grille section with a plastic trim tool of flathead screwdriver! it just clips in. The TPMS antenna is just behind the grille, simply unplug the connector and you can remove the antenna from its housing.
I then switched the ignition on until it recognized there was a fault with TPMS system and then turned the ignition off, replaced the antenna, started the car and its been fine ever since..... worth a try, you never know your luck!
Worldrider
Re: TPMS
Post by Worldrider » Sun Sep 11, 2016 7:03 pm
Thanks.
I've got the exact same issue occurring now. Please post if you attempt the repair…
Current: 07 RS4 Daytona Grey, 987 Boxster S GT Silver, MkV GTI, Honda VFR
Re: TPMS
Post by MikeFish » Sun Sep 11, 2016 8:09 pm
I assume you are getting the 'TPMS' warning rather than the low tyre pressure warning?
MarksRS
Re: TPMS
Post by MarksRS » Sun Sep 11, 2016 8:38 pm
Many thanks for the pic! Back to work tomorrow, but I'll give a try next weekend and report back.
Just TPMS, not low pressure.
Worldrider
Re: TPMS
Post by Worldrider » Sun Oct 23, 2016 1:43 pm
@markrs Did this solution work for you?
Covkiller
Re: TPMS
Post by Covkiller » Wed Oct 26, 2016 9:56 pm
How old are your TPMS sensors as the batteries run out after a number of years. So you will need to replace them or as said disable the antenna.
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 60 guests
