Steering wheel whine
Hi guys
I noticed that on my rs4 if I full lock the steering in either direction I get a whine, does anybody else get this? Is it normal?
Only get the noise on full lock
- Shinobi675
- 5th Gear
Re: Steering wheel whine
Are you sure it's the steering wheel? I get something very similar and comes from slightly to the left.
I finally realised it was only when the wife was in the passenger seat though.
Check your power steering fluid level.
Shinobi675 wrote:Are you sure it's the steering wheel? I get something very similar and comes from slightly to the left.
Haha. Excellent
I presume you've checked your power steering fluid level?. Have had cars in the past that have been noisy on full lock when the fluid is low
Mike beat me to it
Every RS4 i have heard makes a squeal noise when on full lock, mine certainly does toors4uk wrote:Hi guys
As Mike said. Check power steering fluid level. Mine was doing it and a very small top up cured the problem.
You might want to flush the PS fluid too. viewtopic.php?f=35&t=114100
8V S3 cab - Ara Blue
Lotus Evora 400 - Racing Green
Ex owner B7 RS4 - Mugello Blue, B8 S5 Cab - Sprint Blue, D3 A8
I get a squeal when on full lock against the stops.... it doesnt make any noise at any other time.
Initially i thought it was a belt slipping but since the power steering is directly driven from the PTO gears, ive put it down to an ageing relief valve.
My mates RS4 makes exactly the same noise so im not bothered by it.
Might do a flush but its tickety boo otherwise.
This happened me a few weeks back. Was the fluid level. Very small top up needed.
Remember when measuring the level the dip stick is not to be screwed down, just measure when unscrewed. Only takes a second or two of light pour to top up.
Ive had this for 3 years on my car. Where do i top up the fluid??? Need to try!
Audi RS4 Avant
[2014]: blacked out wheels & grill: center res delete : flaps open
[2015]: brembo & yellowstuff : michelin pss : h&r spacers
[2016]: sachs performance clutch : decoked : led there be light : black window trim
[2017]: stertman stage 1 : black headlights & clear corner mod : gruppe m air intake : gutted resonators
The Power steering fluid reservoir is on the right hand side of the engine bay in front of the windscreen washer resevoir. There is a cut out for it in the plastic engine cover.harding wrote:Ive had this for 3 years on my car. Where do i top up the fluid??? Need to try!
Thanks Mike!MikeFish wrote:The Power steering fluid reservoir is on the right hand side of the engine bay in front of the windscreen washer resevoir. There is a cut out for it in the plastic engine cover.harding wrote:Ive had this for 3 years on my car. Where do i top up the fluid??? Need to try!
And how much should i put in there? Will stop by audi in a bit and get some.
Audi RS4 Avant
Users browsing this forum: Google [Bot] and 107 guests
