Front suspension overhaul DIY or not?
audi_do_dat_den
Post by audi_do_dat_den » Tue Mar 01, 2016 8:42 pm
Hello folks,
Im going to overhaul the front suspension links and bushes etc, but is this possible to do yourself or are there special tools required?
I will change out for a Meyle HD kit in the coming weeks hopefully.
audi_do_dat_den
Re: Front suspension overhaul DIY or not?
Post by audi_do_dat_den » Thu Mar 03, 2016 12:57 pm
Hmmm.... i guess thats a 'not' then.... :bigblink:
Harris.
Post by Harris. » Thu Mar 03, 2016 8:35 pm
I did mine myself. Hardest part Is getting the old parts off
esp_mm-270
Post by esp_mm-270 » Thu Mar 03, 2016 11:46 pm
Not a problem if you can get the upper control arm pinch bolt out. They tend to resist removal :(
PaulT
Post by PaulT » Fri Mar 04, 2016 1:36 am
Yep the upper arm pinch bolts are known to seize. I had all upper, lower arms and arb links replaced recently - one side was seized solid and would not shift even using blow torch, ended up with one new upright.
Daytona RS4
Audi Pardner
Post by Audi Pardner » Fri Mar 04, 2016 10:08 am
Agree on the pinch bolts. Mine were a real struggle when I fitted the adjustable spring kit. I doubt they would have come free without a lot of heat, Wurst Rost Off and a 4 post lift. I wouldn't try it at home personally.
Misano Red B7 RS4 Avant. 20" Rotors. KW adjustable spring kit. 8 & 10mm H&R spacers. MRC Stage 2 remap. Pre-cat delete & x-pipe.
rogc
Post by rogc » Fri Mar 11, 2016 12:16 pm
Hi all, where are you sourcing your parts from? TPS? I found a complete Meyle HD kit of bushes and arms but never heard of them! :/
2006 RS4
Users browsing this forum: Majestic-12 [Bot] and 37 guests
