Coilovers , arch rolling advice
controversial
Post by controversial » Sat Jan 09, 2016 6:32 pm
This may not be for the purist but ..
I have a RS4 B7 ... Got masses of adjustment left but want the front lower , problem I'm having I won't be able to turn the wheels if I go lower on the front , rear is perfect . . Ok if I have the front arches rolled will this enable me to get that front wheel tucked into the arch ??
993 RS
RS4 B7
Nononsense Chopper
Harley Davidson Fatboy Custom
ASC
Re: Coilovers , arch rolling advice
Post by ASC » Sat Jan 09, 2016 7:55 pm
Yes. I had to do this as I'm quite low and using spacers.. It rubbed before.
Current - 07 Sprint Blue RS4 Avant Black optics / Buckets / FBSW / MRC Stage 2 / De flapped Manifold / CAF / BMC filter / Decat / Non Res Miltek / Bilstein B16's / Tarox discs, pads and lines / H&R ARBs / 19x9.5 Ispiri ISR1 wheels / MPSS tyres / DTM carbon splitter
Previous - 06 Sprint Blue B7 S4 Avant JHM 91 tune / 2.5" Custom Cat-less DP's / Miltek Non Res Cat back / BMC filter / H&R springs / 19" Fox MS007 wheels/Good Year F1's / EBC TG discs / Yellow stuff pads
andyg72
Post by andyg72 » Sat Jan 09, 2016 9:11 pm
Are you not concerned about the dreaded speed bumps ?
When I lowered mine it used to scrape the bumps unless I drove one side over them ( annoying )
So raised it no scraping
controversial
Post by controversial » Sat Jan 09, 2016 9:21 pm
Not at all bud .... If we worried about things like speed humps it's time to give up :- use alternative route or drive slow
993 RS
RS4 B7
Nononsense Chopper
DavidRS4
Post by DavidRS4 » Sat Jan 09, 2016 9:52 pm
Don't roll the front arches. Have the lip that goes inwards removed. I run 20x10.5 inch wheels all round. That's what I had done. No rubbing whatsoever.
controversial
Post by controversial » Sat Jan 09, 2016 9:58 pm
Any photos of how low your car is ??
993 RS
RS4 B7
Nononsense Chopper
R1RS4
Post by R1RS4 » Sun Jan 10, 2016 8:35 pm
Also how did you finish the edges off? Cheers
RS4 B7 Avant,2007
Metallic black, Black optics pack, Black gloss Wheels, Milltek black tipped -valved, MRC Installed TTS Supercharger 610ps/626nm, MRC stage 3 remap, CAF, DRC/SS+ with H&R spacers, carbon race splitter, carbon trim
Post by MikeFish » Sun Jan 10, 2016 8:58 pm
controversial wrote:Any photos of how low your car is ??
This is Davids car:
viewtopic.php?f=35&t=101189&p=769790#p769760
DavidRS4
Post by DavidRS4 » Mon Jan 11, 2016 5:11 pm
This is Davids car:
Thanks Mike.
R1RS4
Post by R1RS4 » Mon Jan 11, 2016 5:26 pm
Yes thx Mike for the link
Dave, Love the set up
How did they finish the arches edges off? Did they fold the lip back inside?
Do love that RS6 grill, what have you done about the number plate? Rich
RS4 B7 Avant,2007
RS4eddie
Post by RS4eddie » Mon Jan 11, 2016 8:11 pm
highly recommend rolling the fronts!! cheap and very effective mod..and will eliminate 99.5% of rubbing!
2007 RS4 | Phantom Black | Milltek'ed | LED DRL'ed | H&R wheel spaced | 034 Density Line control armed | Hotchkis F + R Sway Barred | K&N Filtered | Ziza lit | Lamix-ed | Passport 9500ix hardwired | Dension Pro BT'ed | StopTech Brake Padded
R1RS4
Post by R1RS4 » Mon Jan 11, 2016 9:08 pm
RS4eddie wrote:highly recommend rolling the fronts!! cheap and very effective mod..and will eliminate 99.5% of rubbing!
What's involved mate and what's cheap mate ?
RS4 B7 Avant,2007
RS4eddie
Post by RS4eddie » Tue Jan 12, 2016 1:05 am
well, I had a guy do it for $50 usd
took him one hour. said the aluminum fenders weren't an issue at all, as some have stated.
R1RS4
Post by R1RS4 » Tue Jan 12, 2016 8:53 am
Nice piece of kit - simples
What did you do with the rear inner arches?
RS4 B7 Avant,2007
RS4eddie
Post by RS4eddie » Tue Jan 12, 2016 6:20 pm
R1RS4 wrote:Nice piece of kit - simples
rears were fine..not needed. are you running in the back too??
