Inlet manifold flap sensor
Grandadg90
Post by Grandadg90 » Sun Jun 21, 2015 5:02 pm
Afternoon chaps.
Currently cars struggling a bit. Car struggles to go at around 3000rpm. The manifold flap position sensor is not functioning. Im getting a fault code of P2014, lower limit reached. Or code 08212. Ive already changed the vacuum solenoid which controls the flaps.
Is the part number I require 03C907386D. Is the part number the correct one?
Daytona Grey, Bilstein Coilovers, Pre-cat delete, Centre resonator delete, IM flaps/vains delete, Interior/Exterior LED kit, CAI, Black Optics.
Other car: Bread Van
Grandadg90
Re: Inlet manifold flap sensor
Post by Grandadg90 » Sun Jun 21, 2015 5:16 pm
Sorry forgot to mention, that I have tried adaption for the position sensor but am getting an error each time. So it must be caput.
orangepeel
Post by orangepeel » Sun Jun 21, 2015 5:47 pm
Bank 1 or 2
Grandadg90
Post by Grandadg90 » Sun Jun 21, 2015 6:14 pm
Its bank 1. I take it, that both banks dont have the same sensor part number.
Rick_RS4
Post by Rick_RS4 » Sun Jun 21, 2015 11:49 pm
just call audi parts or tps and tell them what you want, they are pretty clued up
RS6BRIT
Post by RS6BRIT » Mon Jun 22, 2015 7:24 pm
ETKA lists it as the correct part number but with the suffix B. I suspect it's been superceded by the D suffix however. And they are both the same on bank 1 and 2.
Grandadg90
Post by Grandadg90 » Mon Jun 22, 2015 10:07 pm
Thanks for the replies, I spoke to Audi today and the suffix D, superceded the B.
Seattle-squash
Post by Seattle-squash » Thu Jun 25, 2015 1:21 am
I had same issue, mine unfortunately has w worn bushing/linkage, so I pulled the flaps, left original sensors, and added coding out "flap sensors" options with the JHM tune. Was not worth cost of new manifold/bushings.
Seattle-squash
Post by Seattle-squash » Thu Jun 25, 2015 1:22 am
Mine was bank 2 hence intake had to come off anyways.
Grandadg90
Post by Grandadg90 » Thu Jun 25, 2015 2:02 am
If I do go down the de-flapping route, would I need a kit. I will need a tune, thats a given. Im assuming the breather pipes will have to be re-routed.
RS6BRIT
Post by RS6BRIT » Thu Jun 25, 2015 6:59 am
If you just need the sensor I have a spare you can have. If it's bank 1 as you say it's changeable with the manifold still in place. It's a bugger of a job but it is doable. PM me if you want it.
Have you done a test on the vac system with VCDS to confirm that the flap arms are actually moving ?
Users browsing this forum: Google [Bot] and 73 guests
