8mm spacers - before and after
Re: 8mm spacers - before and after
That looks way better sync, im going to try 8mm on mine with the 275's if it rubs i will just sell them, all depends on ride height, and what looks best
Yes but a handful also said they had rubbing. It's gonna be pretty close. What those that said they had no rubbing didn;t say was how much they load the back up with. I can't believe they have no rubbing with 4 adults in the car and standard suspension. If you have aftermarket springs / shocks such as a set of coilovers, the stiffer settings will stop the car dropping so much with extra weight in the back. Mine doesn't rub with me and the missus in the car, but stick the kids in the back (with my heavy boot install of wood, a big sub and amps and ancilliaries) and I rub over high speed bumps in the road. And that is with no spacers but 265 tyres on an ET26 wheel (equivalent of a 3mm spacer). With 8mm or 10mm spacers it'd rub with just me in the car.Big-blu wrote:This thread lists a handful of guys running 275/30 with 10mm.MikeFish wrote: 275 and 8mm spacers might be too much, 275 and 10mm is defo too much as I said in a post earlier today as the tyre is 20mm wide (10mm on inside and 10mm on the outside) added to a 10mm spacer is the equivalent of a 20mm spacer with the standard tyres and that is just too much with any weight in the back.
http://forums.quattroworld.com/rs4b7/msgs/95440.phtml
Hoping the 8mm works, but I do appreciate the advice.
-Ryan
You might be able to get away with it Silas, depending on ride height and stiffness of your KW v3s.Silas wrote:That looks way better sync, im going to try 8mm on mine with the 275's if it rubs i will just sell them, all depends on ride height, and what looks best
Jay - I'm with u there mate - whilst I don't see the appeal/point of stretching - I do like a subtly dropped car too - hence why I am going with the v3's (plus my front shocks are misting) - I expect my handling to improve as my car seems to love a bit of oversteer as soon as I push on especially round roundabouts.jaysrs4 wrote:I'm gonna get flamed here Sync, but I've always loved a bit (not too much) stretch and a tasty drop = a lovely stance (runs and hides)!!!!
Just purchased some 8mm's ready for my fresh rim refurb on Wednesday.
Can't wait as the rims are the only thing left to do now since I bought the car and they are seriously letting it down!
I'm contemplating spacers for my Avant and will obviously have to inform my insurer. It's a totally stock car. Has anyone been in the same situation, and did your premium increase by much? Don't want to buy a set then find I get stiffed by the insurer
- Virdee Autos
- Trader (Expired)
Those pics really show you the difference 8mm makes
And whoever said that 150mm hub face 10mm spacers are no longer made - bu!!sh!t
We have all 8, 10, 12mm spacers in stock.
Virdee Autos ~ 07950-526592
Anyone successfully running 275/30's with 8mm spacers all round?
I'm on a 275's with standard suspension and are considering 8mm spacers, car look like it needs them but advised they can rub.
I struggled making my mind up as well but used the forums advice....stock suspension 255 tyres 8 mm front 10 mm rear...also cant believe what a difference few mm make
Mugello blue avant black optics...Nearly standard...milltek resonated valved, spaced 10 rear 8 front☺
Why would anyone fit 275's? Cost more money adverse handling and look <beep>.
Inform your insurance company your fitting spacers? Your shitting me. Lol
mf51y wrote:I struggled making my mind up as well but used the forums advice....stock suspension 255 tyres 8 mm front 10 mm rear...also cant believe what a difference few mm make
I have 255 tyres (Goodyear Eagle F1 Asymmetric 2 255/35 R19 96Y XL) and std suspension and am also thinking of going down the 10mm rear and 8mm front. Couple of questions :
- assume these will not rub
- what are the best spacers to get
- approx cost
- do they require longer wheel nuts
Any help appreciated
Cp
R8 v8 - Red, carbon sigma blades.
B7 RS4 Cabriolet - Misano Red Pearl - Non Resonated, Valved, black tipped Milltek. Trupps interior lighting.
AK Cobra Mopar 6.3 - Candy Apple Red.
No they shouldn't rub unless there is something wrong with your suspension.Cp rs4 wrote:mf51y wrote:I struggled making my mind up as well but used the forums advice....stock suspension 255 tyres 8 mm front 10 mm rear...also cant believe what a difference few mm make
- approx cost
Cp
I think most people get the H&R hubcentric ones. Becareful, there are many different flavours so best to buy them from someone that knows theirs beans like user Virdee or site sponsor Revolution.
I've forgotten the cost now sorry.
yes you will need longer bolts, probably best buying them the same time as the spacers. You will also need a new set of longer locking wheels nuts too. Virdee supplied me with spacers, bolt and locks all together.
Great, thx for the quick response.....
Loads of people here been running 275's for ages, not sure how you figure they look <beep>.davers6 wrote:Why would anyone fit 275's? Cost more money adverse handling and look <beep>.
Firstly; apologies if I am asking things that have already been covered in this post (or previous posts) but I'm currently in hospital following spinal surgery and my concentration level is not very good currently.
Seeing the pictures of before & after fitting 8mm spacers I would definitely like to fit them to my B7 saloon. I'm running the standard 255/35 x 19 tyres and simply want to know what are the best 8mm spacers (brand/make/supplier) to order and do I need longer wheel bolts? Obviously I don't want the tyres fouling the arches.
Is it simply a case of removing the wheels, fitting the 8mm spacers front & rear and refitting?
Thanks in anticipation,
CycleSi
CycleSi
Users browsing this forum: No registered users and 92 guests
