Heavy steering
Heavy steering
Hi my steering wheel feels heavy at low speeds I can here abit of whine on the pump but at low speed it does go light but not as light as it use too anyone had any problems like this on they rs4 b7
- Tile Diver
Re: Heavy steering
Well hopefully its not a power steering pump you require, I've just had mine replaced and its not not cheap, €900 for the pump and around the same for the labour!!! Offftttt!!
Black Optics / Ti Pack
SS Suspension +
Sunroof
H&R Hubcentric Spacers
Milltek Res / Valved Cat Back
Stage 2 MRC Map
Cold Air Feed
Carbon Clean
Pre-Cats Gutted
447 PS
If in doubt.. Power out!!
SS Suspension +
Sunroof
Stage 2 MRC Map
Cold Air Feed
Carbon Clean
Pre-Cats Gutted
447 PS
Re: Heavy steering
Or the £150 hose that costs £2k to replace!!!Tile Diver wrote:Well hopefully its not a power steering pump you require, I've just had mine replaced and its not not cheap, €900 for the pump and around the same for the labour!!! Offftttt!!![]()
Have you checked the fluid level?
Re: Heavy steering
Hi yes fluid level fine could be the steering speed sensor playing up
