Remote Key Help
Ivan Good
Remote Key Help
Post by Ivan Good » Tue Feb 10, 2015 9:10 pm
OK
I'm back again. Got the DRC repaired monday, had a 60K service done as well with Audi. Collected the car tonight and the remote key will not work. It was obviously working when the car went in. As I collected the car late on this evening there were no techs about. The service guy has put a new battery in, and tried to re-sync, but no joy.
Any ideas anyone, or is it back to the dealers to be plugged in? :audibash:
mark260684
Re: Remote Key Help
Post by mark260684 » Tue Feb 10, 2015 9:39 pm
If it just the remote central locking not working, it tells you how to do it in the owners manual how to pair the key fob after replacing the battery. I can't remember the exact sequence but it's very easy to do I did it recently when I put a new battery in my remote.
B7 Sprint Blue RS4 Avant,
Milltek non res non valve cat backs,
Decoke,
034 Motorsport alloy intake flap arms,
Led interior bulb kit,
Led drls and side lights,
R1RS4
Re: Remote Key Help
Post by R1RS4 » Tue Feb 10, 2015 9:58 pm
Hi there,
This is what I used
Here it is,
I have only used the first part steps 1 - 4 and it worked fine, so cannot confirm if the rest is ok
Steps to reprogram keys to a car they are already linked to:
1. Press and hold the unlock key on a remote
2. Insert key in ignition and turn to on (while still holding unlock)
3. Hold unlock while in the on position for 2 seconds
4. Turn key to off, remove from ignition and release button.
Do this for each remote. Relink to seat positions (press and hold mem position #, then unlock button for 2 seconds and release both) and done.
To program new remotes on a car never linked to previously:
1. Take a key (valet key works best, put it into the ignition and turn the key to the "on" position, so the dashboard lights come on.
2. Roll down the driver's side window (not required, but a good idea in case there's a problem).
3. Exit the car and close the door.
4. With a second key, physically lock the doors by turning the key clockwise (don't use a remote).
5. Take the first remote to be programmed, press the unlock button. The lights will flash once.
6. Wait 10 seconds and press the unlock button. The doors should unlock. That first transmitter is now programmed.
***If you have only one key skip to step 16. Otherwise continue to step 7.***
7. Lock the door again (physically) with the key, (not the remote) by turning clockwise.
8. Press the unlock button two times with a one second interval in between, the lights will flash with each button press for a total of two flashes.
9. Wait 10 seconds and press the unlock button. The doors should unlock. The second transmitter is now programmed.
***If you have three keys proceed to step 10. Otherwise skip to step 16.***
10. Lock the door again (physically) with the key, (not the remote) by turning clockwise.
11. Press the unlock button three times with a one second interval in between, the lights will flash with each button press for a total of three flashes.
12. Wait 10 seconds and press the unlock button. The doors should unlock. The third transmitter is now programmed.
***If you have four keys proceed to step 13. Otherwise skip to step 16.***
13. Lock the door again (physically) with the key, (not the remote) by turning clockwise.
14. Press the unlock button four times with a one second interval in between, the lights will flash with each button press for a total of four flashes.
15. Wait 10 seconds and press the unlock button. The doors should unlock. The fourth transmitter is now programmed.
16. Remove the key from the ignition.
Make sure that to test the newly program remotes, the original key is removed from the ignition since this exits the programming process. Someone might be a bit frustrated trying to test it with it still in 'program' mode.
I had some difficulty accessing the programming mode. If it doesn't work then take the key out of the ignition and start over. Rinse lather repeat. It will go eventually.
End::;::::::::;:
RS4 B7 Avant,2007
Users browsing this forum: No registered users and 120 guests
