afew pics..
not sure yet, my brother has coilovers on his rs4 and it has a very harsh ride, was thinking h&r springs keeping the drc system???C17LJR wrote:Looking good. What you thinking suspension wise?
its a quattro badge under the rs4..CellDamage wrote:What's that badge under your RS4 one?
quattro.CellDamage wrote:What's that badge under your RS4 one?
maybe try the b5 spring perch mod drops the front by about 3/4 inch?, less hassle than getting the springs modified.jaysrs4 wrote:I've got H&R's on mine only problem is the fronts, the car sits too level.
The rear is perfect, with the tyre walls sitting about a quarter under the arches but there is still a gap up front.
It's far from reverse rake but I'm going to get the front springs modified by a company that make race suspension and springs in Sheffield, they just need about 10mm for it to sit perfect.
So if your a bit anal about your stance I don't think you'll be 100% with springs alone without modifying them.
Coil springs 1989 ? Used them a lot a few others havejaysrs4 wrote:I've got H&R's on mine only problem is the fronts, the car sits too level.
Ah please tell me more!!sar wrote:maybe try the b5 spring perch mod drops the front by about 3/4 inch?, less hassle than getting the springs modified.jaysrs4 wrote:I've got H&R's on mine only problem is the fronts, the car sits too level.
