Adaptive lights
ashy
Adaptive lights
Post by ashy » Thu Aug 14, 2014 8:58 pm
I have had the car a couple of months now and i am getting alot of people flashing me coming the other way. The lights do seem to be a tad high as can see the signs on the side of the roads illuminate quite early. I thought the lights self levelled, they do the side to side up and down thing when you start the car. Is there a way to lower them manually?
stu
Re: Adaptive lights
Post by stu » Fri Aug 15, 2014 2:28 am
There is. Have a look from above on the headlight housing and (from memory) there is a big white plastic screw on each. I don't think they're in the same place left and right housings. Count the number of turns so you don't muck it up! It's a year or two since I did mine and I think even quarter turns make a big difference.
Not really sure why this has to be done since you're right, they are self levelling too. Perhaps the self levelling is only within a limited range?
ashy
Re: Adaptive lights
Post by ashy » Fri Aug 15, 2014 9:15 am
Thanks Stu
Will have a try tonight up against the garsge door. :thumbs:
'R'e'S'pect_4
Re: Adaptive lights
Post by 'R'e'S'pect_4 » Fri Aug 15, 2014 12:35 pm
you cannot just turn screws to adjust headlights, you need to have VCDS (Vagcom) to put the lights in set mode, if you don't the headlights will just keep self adjusting to the preset 'level'.
if could be a faulty level sensor
stu
Re: Adaptive lights
Post by stu » Sat Aug 16, 2014 6:37 am
'R'e'S'pect_4 wrote:you cannot just turn screws to adjust headlights, you need to have VCDS (vagcom) to put the lights in set mode, if you don't the headlights will just keep self adjusting to the preset 'level'.
I did. Or at least I thought I managed it a few years ago! Sorry for misleading you ashy :lol:
I am now the proud owner of a VCDS so may have a go this evening.
ashy
Re: Adaptive lights
Post by ashy » Sat Aug 16, 2014 1:24 pm
No worries
I can see i'm going to have to get this VCDS, aint cheap though is it.
PetrolDave
Re: Adaptive lights
Post by PetrolDave » Sat Aug 16, 2014 6:21 pm
ashy wrote:I can see i'm going to have to get this VCDS, aint cheap though is it.
Just divide the cost of VCDS by the cost of a diagnostic test by an Audi dealer - and VCDS will soon pay for itself.
'R'e'S'pect_4
Re: Adaptive lights
Post by 'R'e'S'pect_4 » Sun Aug 17, 2014 12:25 am
worth every penny :beerchug:
Users browsing this forum: Majestic-12 [Bot] and 367 guests
