Further problems with my RS4 Avant!
Rich'sRS4Avant
Re: Further problems with my RS4 Avant!
Post by Rich'sRS4Avant » Tue Jul 29, 2014 11:30 pm
Thanks guys, relay issues makes sense so will try these. Does anybody know where these relays are located, a part code and where to get them from?
Regards
Richard
Vlan_One
Post by Vlan_One » Tue Jul 29, 2014 11:58 pm
Vlan_One wrote:I think they were two light greyish relays located next to each other in the plenum chamber. It is a mission to get to them. Wipers arms off, plenum cover off, ECU cover (airbox side of the car) off, ECU unscrewed (a bit scared of this one) and lifted up to reveal the relay carrier underneath. It took some force to get the relay out. They cracked the relay casing in the process so be careful in case it is not the relay.
I got mine supplied and fitted by Audi. I can try and get the OEM part no's from the guru at our local dealer in the morning. If you ask your local dealer I am sure they will be able to assist.
Daily: 08 Mk1 Caddy Sport
Toy: 07 Audi RS4 - "un-zorst-flapped"
Previous: 06 Mk5 GTI DSG .:. 96 Mk1 Caddy .:. 00 Mk4 GTI .:. 98 Mk3 GTI .:. 97 Mk1 Deco
Rich'sRS4Avant
Post by Rich'sRS4Avant » Wed Jul 30, 2014 8:55 am
Hi mate if you could Audi Doncaster don't have a bloody clue!
Regards
Richard
Vlan_One
Post by Vlan_One » Wed Jul 30, 2014 12:22 pm
I have some details from ETKA and ELSAWin attached. The Part No is 8E0 951 253 for item 2 and (2) in the ETKA pdf. The remark points to position 2 and 3 on page 3 in the ECU Relays pdf. Hope this helps.
Relays - ETKA.pdf
(51.5 KiB) Downloaded 705 times
ECU Relays.pdf
(80.34 KiB) Downloaded 676 times
RIV
Post by RIV » Wed Jul 30, 2014 12:50 pm
Your problem sounds like the ECM relay to me. Replace both at the same time and check if this resolves the issue. Not an overly expensive part compared to a throttle body.
+1
This happend to mine a few years back, easy fix
Rich'sRS4Avant
Post by Rich'sRS4Avant » Wed Jul 30, 2014 8:56 pm
Thanks all relays swopped and collecting car tomorrow so fingers crossed!
Regards
Richard
Users browsing this forum: Google Adsense [Bot] and 82 guests
