Just when everything it's fixed then I get this who has had
- Jamiestanton
Car was running perfect after new clutch fitted some little problems but there sorted now
Then I get this
Mad noise from the clutch pedal sounds like a ratchet noise as I let off not doing it on stand still just when moving as you release the pedal now and again hope this is something on the back of the pedal
Has any one had this happen to there car
Apart from that everything else is good for now
Then I get this
2006 black audi rs4 b7 mrc stage 2 stage 2 manifold de cats miltek coil overs light weight flywheel black optics 445bhp 470nm
Re: Just when everything it's fixed then I get this who has
Did you have flywheel replaced at the same time?
- Jamiestanton
Yes I changed fly ,slave,master,spring on pedal ,pipe from slave
First few days fine then yestoday started making this mad noise like plastic clicking it's strange maybe something on the back of the pedal I have missed
Only doing it when running
I wonder if there is air in the system
Or the it's adjusting it's self
If it didn't make that noise before you paid £3k for your repair go back and raise merry hell
I had this after my clutch was done, it was the big return spring behind the pedal. Seems when the clutch was out the pedal moved and the spring come off the mountings. Not an expensive part but it came as a shock when it popped out and smacked me in the shin
RS4 Cabriolet - Phantom Black with Exclusive interior
- Jamiestanton
£3k where you been taking your audiCovkiller wrote:If it didn't make that noise before you paid £3k for your repair go back and raise merry hell
- Mr Footlong
So how much did your swap cost then??
Current:
Gone:
Gone:
Oh yes, on mine a couple of months agoJamiestanton wrote:£3k where you been taking your audiCovkiller wrote:If it didn't make that noise before you paid £3k for your repair go back and raise merry hell
Fly wheel, clutch and spring, slave & master, pipe from slave and brake fluid full flush.
£3k Audi Cov
Mind you it works now
- Jamiestanton
Just over £1000Mr Footlong wrote:So how much did your swap cost then??
- Jamiestanton
It was the blue clutch pedal switch making the noise must have been faulty one took it back to tps they swapped it for me I fitted it and every think if cool now
Users browsing this forum: Google Adsense [Bot] and 213 guests
